c4 chassis
Aug 29, 2012 | 12:40 PM
2nd Gear
c4 chassis
Hi all, thanks for reading my post. I would like to put my 383 w/nitrous into a c4 vette but I worry about the chassis
Can the stock c4 handle the high torqe or does it need some sort of chassis connectors like the camaros / novas did?
Aug 29, 2012 | 01:21 PM
Those others were not full frame cars the corvette is.
Aug 29, 2012 | 10:27 PM
2nd Gear
Thanks I thought the c4 Corvette was different because of the 'bird cage,' frame
Aug 29, 2012 | 11:51 PM
Quote:
Originally Posted by
teamster229
Some HD scrap metal runs between the front and rear suspension points
Aug 30, 2012 | 09:05 AM
The "C" beam also helps with chassis integrity.
With sticky tires stub axles & half shafts are likely to fail.
Aug 30, 2012 | 07:16 PM
Obviously the factory thought 400 HP was OK, as that's what the ZR1's made. No differences in the frame between the LT1 Cars and the ZR1's.
Supposedly - the factory had C4 mules with between 600 & 700 HP running around their proving grounds and that was also supposedly about the "limit" on the chassis.
Aug 30, 2012 | 10:05 PM
Aaron at aksracing puts 900+ rwhp through his and doesn't have issues.
Aug 30, 2012 | 10:31 PM
Trans, rear end, suspension, etc... Is what you have to worry about when adding power to these cars.
The car itself will not be over powered.
383 /nitrous is barely even a concern for anything depending if it is stick or not.
Aug 30, 2012 | 11:11 PM
Churchkey
No it doesn't. But the car is fully capable of handling the power.
Sep 8, 2012 | 07:57 PM
minimum weight C4?
vetteoz
Does anyone know how light can you make a 3,400. lb C4 for drag racing?
Using the stock frame and running gear and bare minimum body?
Sep 12, 2012 | 01:00 AM
I know a guy that is putting out just over 1000 HP out of a twin turbo LS1 427 in an 85 and it does just fine with drag radials on it.
Sep 12, 2012 | 06:15 AM
