Help With Oil Temp Sensor
Old Aug 29, 2012 | 03:10 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Default Help With Oil Temp Sensor
On my 90 the oil temp sensor has 3 wires coming off it. Ground, one to the gauge and one to the ECM. I am replacing all the gauges with aftermarket analog and got new sending units with them. My question is, what does the wire to the ECM do? Is this required for the engine to run? If I use the OEM sensor do you think it will display the proper temp on thr new gauge?
Old Aug 29, 2012 | 03:50 PM
Aardwolf's Avatar
Aardwolf
Hmm my '88 had a single blade connector sender above the oil filter. BTW it was difficult to fit an aftermarket oil temp sender there so I used the back not bottom of the oil pan. When the engine was out it could have been re-sized perhaps.
The only benefit I can see of the ECM having oil temp would be to read it in a data log. I am not experienced with '90 code so someone else will have to chime in on if the ECM actually uses it and will set an error code.
OEM sender will not output correctly to an aftermarket gauge. I've tried and they are calibrated differently.
Old Aug 29, 2012 | 06:45 PM
Kubs's Avatar
Kubs
Thanks Andrew! Datalogging makes sense, and good to know it won't work with the aftermarket gauge. If I have to I guess I can install both sending units somewhere.
Old Aug 30, 2012 | 07:52 AM
Kubs's Avatar
Kubs
Anyone else know why the ECM needs an oil temp input?
Old Aug 30, 2012 | 07:31 PM
Purple92's Avatar
Purple92
I know that on the LT1 cars - the ECM would go into a "safety mode" when the oil temp hit 300 F. Power would be restricted (pulling timing), both cooling fans would run full time etc. etc. Not sure if the same is true on a 90, but it's quite possible.
Old Aug 30, 2012 | 07:46 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Can anyone scan in a wiring diagram of the oil temp circuit for a '90? My '89 just had 1 wire to the gauge. I installed the Vetteaid kit and had no adverse effects.
Old Aug 31, 2012 | 01:15 AM
vetteoz's Avatar
vetteoz
Old Aug 31, 2012 | 07:48 AM
Kubs's Avatar
Kubs
Thanks for the image, but I also have that page someone scanned for me before. The only thing it says is "Oil Sensor Input" it doesn't say what it does with that information and/or if it is required.
Old Aug 31, 2012 | 01:34 PM
Black89Z51's Avatar
Black89Z51
We need to see the wiring diagram for your ECM. Also, the block that says "See engine data sensors" may also help, we just need the 8th number of your VIN to get the correct page.
Old Aug 31, 2012 | 05:27 PM
Kubs's Avatar
Kubs
I will be with the car tomorrow so I can grab the VIN.
Old Aug 31, 2012 | 05:45 PM
383vett's Avatar
383vett
The oil temperature sensor is above the filter and has one blade. The oil pressure sensor is on the block behind the intake manifold to the driver's side of the distributor. This has three wires.
Old Aug 31, 2012 | 06:04 PM
Kubs's Avatar
Kubs
Yes the pressure switch also has 3 wires. Apparently the temp sensor changed to a 3 wire sensor starting in '90. This is the sensor in my old block:
Old Sep 1, 2012 | 01:04 AM
Cliff Harris's Avatar
Cliff Harris
The sensor behind the distributor is a combination of oil pressure sensor and oil pressure switch. The sensor goes to the dashboard oil pressure gauge. The oil pressure switch bypasses the fuel pump relay so you'll have fuel pressure if the relay doesn't work for whatever reason.
In earlier L98s there was a separate oil pressure sender and oil pressure switch.
Old Sep 1, 2012 | 01:37 AM
vetteoz's Avatar
vetteoz
We need to see the wiring diagram for the block that says "See engine data sensors" may also help,
Doesn't add any info , just shows those wires grounded in the ECM
As shown in the '90 circuit diagram I posted above
Old Sep 1, 2012 | 08:55 AM
rodj's Avatar
rodj
IIRC ,
I remember reading on here that the ECM monitors oil temps as part of it's calculations for bringing up the Change Oil Light
Old Sep 1, 2012 | 02:00 PM
Dyno Don L.'s Avatar
Dyno Don L.
Those 3 wires should be battery, fuel pump and oil sender to gauge.
Old Sep 1, 2012 | 06:47 PM
Kubs's Avatar
Kubs
You guys are talking about the OIL PRESSURE SWITCH. I am talking about the OIL TEMP SENSOR. Different location.
Originally Posted by rodj
IIRC ,
That would be good. I dont have the change oil light anymore. Sounds like I am OK and the engine will still run?
Thanks for the extra info.
To Help With Oil Temp Sensor
Old Sep 1, 2012 | 08:30 PM
rodj's Avatar
rodj
I have not seen anything in your '727 or '730 MAP ECM's (the identical F-Body version ) programming that has any requirement for a oil temp input
as part of it's engine operation
Old Sep 1, 2012 | 11:11 PM
Corvette40's Avatar
Corvette40
I believe in 1990GM combined the oil temperature and pressure sender into one unit and mounted it over the oil filter. When I helped install the FIRST intake on an 87 vert, the canister type pressure sender would not fit behind the distributor so we converted to the three wire temperature/pressure sender. It was pretty easy to do, and when I drop my new 355 in my 88 next month I'm going to convert mine. It makes changing the pressure sender much easier.
Old Sep 2, 2012 | 08:28 AM
Black89Z51's Avatar
Black89Z51
The Corvette still has a separate oil pressure switch/sender that has 3 wires right next to the distributor. As mentioned before, the wire to the ECM was to monitor oil life, not for pressure.
