bushing replacement
Old May 31, 2002 | 02:53 PM
KVETTE65's Avatar
KVETTE65
5th Gear
Default bushing replacement
I wanted to know how much of a difference polyurithane bushings make. The repair shop i use said they only install the rubber bushings. I don't know if i need the polyurithane bushings. I don't auto-cross but i am planning on putting a 400 hp engine in in a few years. I don't want to have to upgrade the suspension again when i put the engine in. I have an 84 corvette. The ride is a little rough now but that could be because of the worn out bushings. I am looking for a better ride because i will be driving it every day for the next few years. Also if anyone has switched to coil-over shocks how much of a difference did that make in the ride quality and handling, having independent suspension. Thanks for your help
