zf maintenance question
Old Sep 2, 2012 | 11:37 PM
Impala Balko's Avatar
Impala Balko
Default zf maintenance question
I am trying to drop the zf tranny on my 94 6-speed coupe and I wanna make sure I have this thing high enough on jack stands. How high do I need to get this car to get this tranny out of this car
Old Sep 3, 2012 | 12:09 AM
cv67's Avatar
cv67
St. Jude Donor '05
As tall as the tranny is thats it unless you need more crawl room
Old Sep 3, 2012 | 12:32 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
The frame needs to be lifted about 2ft. The biggest unexpected is how tall the stock shift stands. You'll either need to roll the trans a bit -- to get it out of the tunnel -- or go even higher.
With my "standard" floor jack, I used a 4"x"4 to get a bit higher. The 6-ton safety stands didn't need "shimming" though. But the extensions were up close to the limit.
IIRC, I rolled mine on the side to pull it out. Probably had it up about the 2' I suggested.
Maybe this will give you an idea....(I'd let the rear down before this pic.)
Old Sep 3, 2012 | 11:02 AM
96GS#007's Avatar
96GS#007
If you roll the transmission to the side, you can get it out from under the car even if the car is only 14"-16" in the air. Put it this way....if you have decent jack stands...not the $20 specials....raise them as far as they'll go and you'll be fine.
Regarding the shifter...there is a simple support brace on the rear of the shifter. As I recall, there are two bolts...10mm...that secure it to the transmission body. Remove those two bolts, set the brace aside, and the shifter can be pivoted downwards a couple inches. Makes it a little easier.
Old Sep 3, 2012 | 11:35 AM
Impala Balko
I never thought of putting it on her side, I thought it would cause fluid to leak out..... Speaking of fluid which lube works the best in these ZF trannys.... I know zf doc recommends the castrol BMW stuff but is there better stuff available or is that it.
Old Sep 3, 2012 | 11:59 AM
VetteMed's Avatar
VetteMed
Good idea to drain it before you drop it, unless you have a plug for the tailshaft. It will cause a big mess when you tilt the tail down otherwise.
Old Sep 3, 2012 | 03:58 PM
96GS#007's Avatar
96GS#007
Old Sep 4, 2012 | 12:38 AM
Impala Balko
Does anyone have a breakdown of the tools that I need so I am prepared.... I really am flying blind on this one.
Old Sep 4, 2012 | 08:45 AM
GREGGPENN's Avatar
GREGGPENN
17mm allen is the biggey -- for pulling the fill/drain plugs. Everything else you'll have -- assuming you're a wrencher.
I'm thinking you won't have a reverse lockout ring -- which also requires a (sortof) specialty allen.
Old Sep 4, 2012 | 10:35 AM
Impala Balko
When I pull the tranny do I just separate the tranny from the bellhouse.. rather than take it out as a whole.... The reason why I am doing this is because my clutch fork is hyperextending and rubbing against the pressure plate.... So I need access to the fork and pivot stud.
Old Sep 4, 2012 | 10:56 AM
VetteMed's Avatar
VetteMed
You can't access the fork and pivot without removing the bellhousing. Remove trans, then remove bellhousing.
Old Sep 4, 2012 | 12:47 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
To get the Vette high enough, you will need four-6 Ton Jack Stands. It can be done with 4-Ton jack stands, but you will have to tilt the tranny for it to clear the floor/chassis.
Yes, drain the oil first.
Required Tools (wrench and sockets for each):
21mm, 19mm, 17mm, 16mm, 15mm, 14mm, 13mm, 10mm, 8mm
A 1/4" X 12" standard screwdriver (Support beam alignment leverage bar)
Full size rolling floor jack, (4) jack stands, support stands under front
control arms and rear shock studs.
Bell housing (L98/LT1/ LT4) P/N 10126448 ~ $200 (it will be an updated -
magnesium/aluminum blend w/vents P/N 10085208)
FYI - '90-'95 Bell housing (LT5) P/N 10085201 ~ $800
O.E. Clutch Assembly (by Valeo) from Carolina Clutch (phone # 888 462-2739)
~ $300 delivered.
Note: Clutch Assemblies by CenterForce or McLeod Industries are build upon stock Valeo Pressure Plates.
REMOVAL OF TRANSMISSION:
1) Remove the Shifter **** (see procedure below). Remove the lift-ring by using a 0.077" Allen wrench (if equipped), leather-boot by removing the center console and
4 egg corn nuts connecting the shift boot to the shifter.
2) Remove the exhaust system as one piece from after the catalytic converters.
3) Disconnect electrical connections from Reverse Light Switch, CAGS and Speed Sensor.
4) Support the transmission with floor jack centered at drain plug.
5) Remove drive shaft and support beam bolts.
Manipulation by varying support height with floor jack may
assist in driveline support beam bolt removal.
6) Slide support beam forward from differential mount far enough to clear the differential structure when lowered.
7) Monitor the firewall clearance while lowering the support jack allowing the engine and transmission to tilt backwards until the drive beam clears the
emergency brake cable. You will have to help the cable around the back end of the beam. The emergency brake must be completely released for this step.
8) Slide support beam rearward from the transmission and remove from vehicle.
9) Remove transmission to bell housing bolts.
10) Engage 3rd gear to allow for the shift lever to clear the tunnel when transmission is being removed.
11) Remove transmission from vehicle.
REMOVAL OF THE BELL HOUSING:
Remove the bell housing by aligning the fork on the two flats of the release (throw out) bearing and pull the fork back from the bearing while rotating the bell housing in a counterclockwise direction.
Note: Excessive clutch disc wear may require loosening of the ball stud to disengage fork and bell housing.
- The 6mm Allen socket ball stud locking screw is a
counter-clockwise turn-to-loosen thread and is tightened to 10 lbs-ft. The torque spec in the manual is incorrect.
- The 12mm Allen socket fork ball stud is a clockwise turn-to-loosen thread (left handed) and is tightened to 33 lbs-ft. NOTE: If the fork ball stud is not able to be loosened/removed (clockwise rotation), the allen socket portion of the threaded stud has cracks in it allowing it to expand remaining locked in position. This happens more often than one would expect likely due to the thread being the opposite direction thread type where counterclockwise rotation actually tightens the ball stud more so resulting in cracking the thread portion of the ball stud. Removal of the stud once the thread portion has cracked is best done buy CAREFULLY cutting the stud in half by using a cut-off wheel through the retainer hole of the bell housing. Once the stud is severed below the shift fork, the bell housing can be removed and a 1-1/8" socket can be used to back the stud out for replacement. When backing the stud out from the flywheel side, it is to be loosened by rotating in the counterclockwise direction.
Caution: Do not let the clutch hydraulic slave cylinder (actuator) hang from the feed line.
Be sure to secure the actuator off to the side in a horizontal position. This will reduce the likelihood of any suspended debris in the clutch hydraulic fluid from settling in the actuator at the seal which can lodge in the seal and possibly compromise the clutch hydraulic system.
***CAUTION*** Do not, under any circumstance, use any type of leverage bar between transmission and bell housing. Manipulation by varying support height with floor jack may assist in aligning the bolt holes.
R&R of the Shifter ****:
NOTE - If the shifter **** is being removed for the first time, it may require a great deal of effort to pluck the locking wedge out of position. The following procedure will allow you to get into the correct position to generate enough pull force required to get the job done.
1) Remove the roof panel (you will need to stand up in the car get enough leverage to pluck the wedge from the shifter ****). It will be necessary for you to straddle the door sills in order to get your body in the correct position for max lift/pull leverage.
2) Remove the shift pattern cap with a small leverage/prying devise. With a small set of Vise-Grip pliers, lock onto the sides of the wedge that is just under the shift pattern cover of the ****.
3) with a long screw driver slid through the pliers jaws, use both hands and pull up with as much force as you can generate.
4) Once the wedge has been removed, unscrew the **** to access the reverse pull-up lock-out mechanism (if equipped). The reverse pull-up **** is held in place with a very small allen-head set screw.
R&R of the extension housing bushing:
NOTE - When removing the extension housing from the transmission case, be sure that the rear main bearing shim remains in place. If the shim should be removed for whatever reason, be sure that it is back in place when the extension housing is re-installed. Failure to follow this step will result in failure of the transmission.
NOTE - Be sure that any deformities caused by removal of the old bushing are removed from the aluminum bore. The dimples of the original bushing tend to leave slight wakes in the Aluminum bore as the old bushing is pressed out of place. For best reinstallation of the new bushing, make sure that the high spots of these wakes are removed along with any other protrusions caused by dents in the aluminum bore. If there are a few dents or gouges remaining in the bore, it is OK. You just need to be sure that all of the high spots have been removed so that the new bushing sits perfectly true.
NOTE - Do not be concerned that the new bushing does not have any dimples like the old one. The replacement bushing is to be pressed into place without any lubricants or binding agents. The combination of fit between the two different types of material and their coefficient of expansion properties will provide for an exceptionally good "hold in position" of the bushing when unit is returned to operation.
1. Remove the tail shaft seal.
2. Remove the bushing from it's journal buy cutting the bushing (with Sawzall) along the oil channel grove so as not to damage the bushing journal.
3. Use a scotch pad to thoroughly clean the bore surface and the bushing outside diameter surface.
4. Carefully press new bushing and seal into place. NOTE: This bushing is the same bushing used in a T-400 automatic transmission. NOTE: be sure that the rear main bearing shim is in place prior to re-installing the extension housing.
5. Be sure to evenly torque the extension housing bolts to 18 foot pounds of torque.
Shifter Removal:
1. Remove the shifter bracket at the back of the transmission.
2. Unbolt and remove the shifter control-arm Allen bolt.
3. Cut and remove the shifter bellows lower front tie-wrap.
4. Pull and hold back the bellows in order to gain access to the drift pin safety retainer ring.
5. Slide the retaining ring back and push the drift pin out enough to remove the shifter.
Changing the Speedometer Gears on the Vehicle
NOTES: The C4 Corvette Vehicle Speed Indication System (VSIS) uses a pulse-signal-reference generated from the Vehicle Speed Sensor (VSS). The VSS, when equipped with a 15 tooth (T) drive gear (on output shaft) and 42T driven gear turning the VSS combined with a 3.45:1 differential ration, produces 4000 pulses per mile traveled. The VSIS is calibrated to 4000 pulses equaling one mile. When the differential (final drive) ratio changes, so does the pulses generated over each mile. To correctly recalibrate the VSIS signal pulse rate back to 4K/mile either the drive and/or driven VSS gear(s) must be changed or a black box Electronic Ratio Adapter (ERA) installed. Both cost around $140.
DIRECTIONS:
- Raise vehicle and safely support on jack stands.
Remove or Disconnect
- Exhaust.
- Driveshaft-to-pinion strap bolts (8mm).
- Driveshaft. (little to no oil should leak out).
- Vehicle Speed Sensor 10mm bolt.
- Vehicle Speed Sensor.
Note: Roughly 1/4 of a liter of oil will drain out of the transmission.
- Driven gear from Vehicle Speed Sensor.
- Drive gear off of output shaft.
To do this, you will need to rotate the shaft until the speed sensor drive gear clip is visible.
Push in on the locking tang of the clip then slide the driven gear back and off of the output shaft.
NOTE: The speedo drive gear will clear the extension housing tail bushing and seal.
Leave the washer in place for the new speedo drive gear.
Install or Reconnect
- Speed Sensor Drive gear and locking clip.
- Driven gear onto Vehicle Speed Sensor.
- Vehicle Speed Sensor 10mm retaining bolt.
- Driveshaft.
- Oil into the transmission to replenish what was lost.
Note - add oil through the fill plug hole until it runs back out of the hole.
- Exhaust.
Old Sep 4, 2012 | 02:25 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
The above post is excellent.
As for fluid, I have used Pennzoil Synchromesh which worked fine, but now I'm using the Amsoil Synchromesh. The Amsoil seems to shift smoother, so I'm going to stick with that.
Impala Balko
Nice write-up thanks
Old Sep 4, 2012 | 04:34 PM
mazdaverx7's Avatar
mazdaverx7
beautiful writeup!
Old Sep 4, 2012 | 06:03 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
You can screw the pivot ball forward w/o removing the bellhousing. There's a allen hole for that purpose.
After it's unscrewed you can then take the bellhousing off w/o fear of bending the fork.
Old Sep 4, 2012 | 09:09 PM
VetteMed's Avatar
VetteMed
That's right, I forgot about that allen hole.
To zf maintenance question
Old Sep 7, 2012 | 01:58 PM
Impala Balko
update.... my car is elevated approx 2' in the air, exhaust is off from the LT headers back. I kind of hit a bump though... How do I get the drive shaft off. I took off the straps that hold the U joint on but it won't budge.
Old Sep 7, 2012 | 02:17 PM
BrianCunningham
May need to persuade it a bit
The bearing is a little oversized for the hole
that and a little rust.
just don't go to overboard.
Old Sep 7, 2012 | 02:25 PM
Impala Balko
I have to run out and grab some tools... anyone know what size the drain and fill plugs are on the a blue tag ZF-6
