LT1 - front seals
Old Sep 4, 2012 | 06:26 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Default LT1 - front seals
One of the front seals is leaking already on my motor. Had all three replaced just a year ago. I've also got a friend that owns a shop that's had to replace the opti seal on a 96 four times in just the last couple of months (last couple the car never left the shop). Both mechanics are using the proper tool to set the seal, but yet both cars keep leaking. Are the GM seals still the only way to go, or are there other options that might work better? Are there any options? I've done a little searching (like on rockauto), but haven't found anything that looked promising. Thanks.
Old Sep 7, 2012 | 10:54 AM
JohnnyRedVet's Avatar
JohnnyRedVet
4th Gear
Just some ideas. I know on my '92 the timing cover gasket was weeping a little and may make it appear that one of the front seals are leaking. You mention proper seal tools. Are they using the bullet shaped tool to install the water pump seal - this one is a little tricky even with the seal installation tool. From what I read, the water pump seal should be put in dry. I got a little mis-aligned installing it the first time and decided to pull it and put another in so I would not have to re-live the job again. Is the water pump seal the one that could be leaking down towards the opti seal?
As far as the opti seal - I didn't feel it was the best or robust I've seen as far a design. This seal went in easily for me - almost too easy It felt like it would go in too far if push enough. My only thought here is that there may have been too much wrestling around with installing the opti since lining up the splines can be a bit tedious. The first opti I installed (Chandler- died in one year), I got lucky and the spline line up perfectly - didn't need to take the cap off to fuss with it. The second opti (MSD - almost done installation), fit too tight and I had to wire brush the spines to get a fit. This meant multiple mountings to get a smooth fit which I hope did not "exercise the seal very much.
Good Luck
Old Sep 7, 2012 | 01:37 PM
96GS#007's Avatar
96GS#007
Sounds like the shop is installing the seal wrong. If the seal is installed incorrectly on the tool, the lip still ends up facing the wrong direction which then results in a leak.
I've used GM and FelPro seals with success.
To LT1 - front seals
