Where does this go?
Old Sep 7, 2012 | 09:37 PM
c4_4ya's Avatar
c4_4ya
Default Where does this go?
Well this car is like a box of chocolates... Just found that the heater core has been bypassed, then found this tucked up out of sight...
Has a black/white wire and an off grey or beige wire...
Oh yeah, 92 6spd.
Old Sep 8, 2012 | 09:31 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
manifold air temp under the plenum.
there is a secondary harness that plugs into that and is about 10 inches long and goes to the manifold air temp sensor
Old Sep 8, 2012 | 09:52 AM
c4_4ya's Avatar
c4_4ya
Where is the MAT sensor on an LT1? I know where it is on TPI cars...
Old Sep 8, 2012 | 10:10 AM
coupeguy2001
well since you did not tell us what year your car is, I used the TPI, but yours should be out in front of the throttle body.
Old Sep 8, 2012 | 10:15 AM
c4_4ya's Avatar
c4_4ya
Last line first post... 92 6spd. I think I found it in the FSM, looks like the low coolant sensor. FSM p.6D5-3 shows it not connected in the diagram so maybe it's supposed to be disconnected? Shows as disconnected in diagram from LT5 also...
Old Sep 8, 2012 | 11:21 AM
HammerDown's Avatar
HammerDown
I found the low coolant sensor connector in my 94 LT1 just dangling down near the firewall a while back, after I removed the coolant tank to do some cleaning. The pins in the tank connector had corroded and one of them broke of in the wiring harness connector. Not sure how long it had been like that, or if I broke it of when I removed the tank (because I didn't realize there was a connector under there).
To Where does this go?
