water temperature
Old Jun 1, 2002 | 04:51 PM
michelc4's Avatar
michelc4
Default water temperature
the fan of the radiator of my c4 start at 110 ° celsius and stop at 98° C
is it correct data for my engine?
do i need to check my ECM ?
thanks
Old Jun 1, 2002 | 05:21 PM
Husker Vette's Avatar
Husker Vette
From: Are you the bug or are you the windshield.....
Default Re: water temperature (michelc4)
My 86 L98 kicks in between 227 and 229 degrees farenheit and then turns back off aroun 212 degrees.....
Not sure what the conversion factor is to get to celsius, but maybe someone else can help out with that....
Old Jun 1, 2002 | 06:38 PM
vader86's Avatar
vader86
sounds about right for celsius
Old Jun 1, 2002 | 06:43 PM
ZAD54's Avatar
ZAD54
If my conversion is right your fan is coming on at around 230 and going off at 208.4 F. Sounds about right if its a factory coolant switch in the head. You might want to change it to a lower on if that bothers you, I like mine a little cooler than that. :cheers:
To water temperature
