I would pull each wheel and check each abs sensor for metal debis build up. The metal debris on them is from the brakes and the senors are like magnets. This sometimes will give you warnig lights. Clean them up and see what happens.
If cleaning them doesn't work then check to make sure that they are getting signal. If they are then check the relays which are in the system behind the drivers seat.
Thanks for the great information. I have decided that since I want to pull the wheels to clean up the suspension, and hopefully eliminate squeaks, I will tackle this at the same time. Now that Fall is here, I will likely wait until cold weather has settled in and driving days are down, to put the car up on jacks.
If it's the relay? I got mine from vette2vette for $35. They are great for Parts!
I am thinking about disassembly of the front suspension to grease up and hopefully eliminate some serious squeaking when hitting bumps. I have average mechanical abilities and a decent set of tools (no specialized automotive tools). After looking it over, I am concerned that I might get in over my head. You know, take something apart and cannot get it back together.....I appreciate any feedback from this that have been down this path!
