Is this to much Cam??
Old Jun 1, 2002 | 05:17 PM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Default Is this to much Cam??
I reciently bought a Lingenfelter 74219 Cam and was going to purchase a SR Intake, but I just don't have enough money. (Just bought a house)
So I found a ported Plenum, ported Manifold and ported AS&M Runners and was thinking of using it with the 219 cam, a set of 190 AFR heads, 1.6 Roller Rockers, 52mm TB and a set of Hooker Longtube headers.
I know this Cam was designed for the SR but how well do you think it would work with a Ported stock intake w/ AS&M runners? How much can a Ported out Plenum/Manifold/Runners flow v.s. a SuperRam?
Oh I should add here the goal is consistant mid 12's. :)
[Modified by Mr. Magoo, 4:22 PM 6/1/2002]
Old Jun 1, 2002 | 05:48 PM
gtsyellow's Avatar
gtsyellow
Default Re: Is this to much Cam?? (Mr. Magoo)
i think it would run fine, do some prom work after you run the dyno to make sure your air/fuel is in line and enjoy. the 219 cam really isn't that large, the hot cam is even larger and they seem to work alright on worked TPI setups even though they work even better on shorter runners. i still for the life of me can't figure out why people like the super ram so much, they are a bizatch to work on and have leak potential worse than factory TPI. i think TPIS needs to have a forum test drive day on the miniram along with a wrenching session. i have a feeling they would be selling more manifolds :yesnod:
Old Jun 1, 2002 | 06:33 PM
vader86's Avatar
vader86
Default Re: Is this to much Cam?? (gtsyellow)
No, just needs some tuning
Old Jun 1, 2002 | 07:01 PM
J Z06's Avatar
J Z06
Default Re: Is this to much Cam?? (vader86)
For the time being, I don't see why it wouldn't run well. Like the others mentioned...re-tune it and you'll be good to go(hopefully). That Scorp combo is sure feverish isn't it? :) I can imagine what it sounds like, I am similarly configured.
JD
Old Jun 1, 2002 | 07:22 PM
scorp508's Avatar
scorp508
Mark you'll be fine. :yesnod:
Old Jun 1, 2002 | 11:26 PM
Vic'89's Avatar
Vic'89
Magoo
I am going with the same setup you are talking about.
My first combo will be 219 Cam/ AFR heads/ Accel base / AS&M runners, I am looking for low 12's.
Next combo will be with the Superram.
Vic
Old Jun 1, 2002 | 11:56 PM
Mr. Magoo's Avatar
Mr. Magoo
Default Re: Is this to much Cam?? (Vic'89)
That's cool Vic! :cool:
I must admit that both Scorps build-up and your times and mods have been a real inspiration for me to dig into this motor.
Old Jun 2, 2002 | 08:40 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Sounds like a good combo and I think you can see a realsitic 350 HP or more.
Torque is going to be in the 400's easily.
(that with 3.73 gears...my god youre going to have traction problems at idle) :D
Btw,if you have the '86 if I recall,you going to retrofit the 219 in the non roller block?Or is it a hydraulic flat tappet version of 219?
Just wanted to be sure.Retrofitting cost extra money and misc parts if you dont have them yet.
Old Jun 2, 2002 | 09:16 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: Is this to much Cam?? (Bill's86Coupe)
Go for it and let us know how she runs.
:cool: :cool: :cool:
Old Jun 2, 2002 | 10:04 AM
Mr. Magoo's Avatar
Mr. Magoo
Hi Bill,
Yes it is a non roller block '86, So I'll need a few more parts to get the Cam to work. But I think the gain will be worth it. :)
350 HP and 400 Torque.................................m an does that sound nice!! :lol:
This project is going to start late Fall after I buy the remaining parts. In the mean time I'm going to make many more 1/4 runs and a few Dyno runs with my existing set-up to develop a starting point. I'll post all of my results. :)
Old Jun 2, 2002 | 10:15 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
That cam has it's place, It's fime in most applications.
To Is this to much Cam??
