88 corvette best performance mod
-toss the "frisbee" disc from the front of the WP pulley-10chp
-install a 160 deg T-stat-10chp
-cut-back electrode AC Delco spark plugs-8chp
-cut the air filter lid & install K&N filter-10chp
-toss the spare & jack; run 1/4-3/4 tank of fuel~100lb reduction=10chp
These should cost maybe $100.
To "feel" a surge install a 2,000rpm TC and TransGo shift kit. This will give tire shredding starts and tail-wagging 1-2 shifts. This will likely cost >$500.
To get more power free up the exhaust with 2 1/2" mandel-bent front Y, hi-flow cat and hi-flow cat-back. These will cost >$500.
Also, run ~35psi in tires for optimum handling.
Have fun with your new '88 Vette...
The following link includes several pages of technical C4 info, so read through the sections, and get a grasp of the sophistication of your vette: http://www.corvettephotographs.com/c...cts_launch.htm
Hope you have good luck and enjoyment with your new addition.
Get yourself an FSM.
