1991 zr1
Old Sep 18, 2012 | 05:45 PM
RBK191's Avatar
RBK191
Default 1991 zr1
I got a 91 ZR1 12,000 miles. Minor miss (flutter) gets worse as engine heats up. Local Chev dealer unable to diagnose, partially due to, they say, they don't have the tech 1 diagonistic instrument/tool. Does anyone know a GOOD LT1 mechanic or know who might have the Tech 1 diagnostic devise. I'm located in Fayette county...near Uniontown.
Any info will be appreciated.....Thanks
Old Sep 18, 2012 | 05:51 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
LT5 mechanic
Old Sep 18, 2012 | 06:32 PM
RBK191's Avatar
RBK191
Default 1991 zr1
Typo error.....should be LT5 mechanic
Old Sep 18, 2012 | 06:48 PM
leesvet's Avatar
leesvet
A museum quality car can get away with a sputter...
what a "find".....
Those cars are as rare as virgins after home coming...
Old Sep 18, 2012 | 06:56 PM
RBK191's Avatar
RBK191
LOL on your comparison to virgins....funny! However, I can't stand it when it doesn't run right. Got any ideas?
Old Sep 18, 2012 | 07:18 PM
1986coupe's Avatar
1986coupe
Check for vacuum leaks or leaks around the air intake or throttle body. It is possible that when it heats up it is getting too much air from somewhere.
Just a thought.
Old Sep 18, 2012 | 08:59 PM
Kmcoldcars's Avatar
Kmcoldcars
So where is Fayette county and Uniontown? I am in Pierce county, in Puyallup. I am sure you know where that is.
If we know where you live maybe some suggestions of who can work on a LT5 can be made. I know it would NOT be a Chev dealer.
Old Sep 18, 2012 | 09:04 PM
RBK191's Avatar
RBK191
Default 1991 zr1
Just a thought.
Thanks for the suggestion, however we covered that already....found several small leaks....corrected them but still have problem
Old Sep 18, 2012 | 09:06 PM
RBK191's Avatar
RBK191
Fayette County is in Southwest Penna. south of Pittsburgh PA
Old Sep 18, 2012 | 09:23 PM
leesvet's Avatar
leesvet
My best guess would be a dirty injector....the age of the car is troublesome...although it is a remarkable piece of history and mechanical art, yrs ahead of its time, its still subject to time. It does not take much at all to ruin the internals of a delicate system thats as precise as fuel metering. The Z back then was just like the avg gen-1 chevy...just twice everything. The birth date tells me that the ethanols since then have probably done a little damage to inj insides, and the possibility of being improperly stored at some point has to be considered.
I'd go thru the plugs and look for a couple that were burning slightly different. That might help ID the suspect cylinders.
As simple as it sounds...dose it with Marvel Mystery oil in the gas to see if that might loosen sticky or slow injectors. The ohms testing only speaks to the electrical workings...fuel injectors are also mechanical and have moving parts that get gummed up from sitting with fuel.
Old Sep 18, 2012 | 09:57 PM
cv67's Avatar
cv67
St. Jude Donor '05
Lots of guys use the RC inectors. Check the C4Zr1 section here or the zr1.netregistry site there is a lot of info and helpful members sure one in your area that knows of the right wrench to help.
Like leesvet said more than likely those old multecs are going bad. Coils can act funky when they get that way too. Need to find someone in your area that knows those cars specifically. The guys at the registry will help you out.
Old Sep 18, 2012 | 10:31 PM
AirForceOne!'s Avatar
AirForceOne!
Wow 91 ZR-1, with 12,000 miles! PICTURES, PICTURES, PICTURES!
To 1991 zr1
