Opti Replacement
Old Sep 20, 2012 | 12:55 PM
cnorgaard's Avatar
cnorgaard
Navigator
Default Opti Replacement
1996 LT1 175,000: Have to do a new crankshaft so I'm doing the timing chain and Opti at the same time. When the timing gears/chain are at 0 TDC do I just align the slots in the Opti and camshaft? or could the Opti be 180 degs off and there's some trick to make sure it's not?
Old Sep 20, 2012 | 02:14 PM
cnorgaard's Avatar
cnorgaard
Navigator
I found the answer elsewhere in this very good forum. Just make sure the splines are aligned correctly and no effort is required to get it to seat. But if anyone has different experience I'm listening.
Old Sep 20, 2012 | 07:53 PM
STL94LT1's Avatar
STL94LT1
Your 96 has a Gen II opti, no splines. It is driven by the camshaft's dowel pin.
Old Sep 21, 2012 | 09:11 AM
cnorgaard's Avatar
cnorgaard
Navigator
Many, many thanks SLT94LT1. Nothing this good in the '96 GM manual. - CNN
To Opti Replacement
