Bye Bye TPI
Old Sep 21, 2012 | 05:45 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Default Bye Bye TPI
I'm just getting started on my intake change project. This intake is not seen very often and I think it may be worth a shot. It is the Edelbrock Pro Flo XT and I really liked the look of it so it was my choice. If it performs as good as it looks, (IMO) then it will be worth every penny of it's $439. price tag. This is just for the manifold, the throttle body and fuel rails are extra but I have just over $800. in all three pieces which is usually what a used superram goes for plus, Vette magazine did a test on it and got 20 more hp over the superram. Here are some pics of it as I just put it on.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Sep 21, 2012 | 05:47 AM
Dynamo6969's Avatar
Dynamo6969
god that is beautiful! let us know if you have any hood clearance issues, im looking in to this for my '89 (or HSR or miniram)
cant wait for some results!
Old Sep 21, 2012 | 08:01 AM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
What's not to like?
Edelbrock, powder coated & black!
Looks absolutely stunning!
Let us all know how that puppy goes!
PS Who makes the Throttle Body & what size?
Old Sep 21, 2012 | 08:35 AM
Midnight 85
I have about 1/4 to 3/8 inch clearance and with the way the hood is curved in that area I don't think flex will even bother it. My throttle body is a polished piece from Summit, I have heard there COULD be slight grinding to do to a stock ls tb. Please be patient I still have a lot of pricy items to get before it will be running again, probably early to mid spring. I agree, I can't wait to see what it does for performance.
Sorry Torch Red, I left out the size of the tb. I opted for an 80mm but the same tb is available in 85mm
Old Sep 21, 2012 | 09:07 AM
shakedown067's Avatar
shakedown067
Looks FANTASTIC! Now I just need someone with an 88 or newer to do this mod and sell their old intake dirt cheap to put on my truck!
Old Sep 21, 2012 | 09:08 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
It was forum member USAsonlyway who did the swap on his car in the Vette article. He really enjoys it, hopefully he sees this. This intake was one of my options looking for an intake, but I settled on the single plane.
Old Sep 21, 2012 | 09:14 AM
Midnight 85
That article was a major reason I went with this intake. I am really pumped about seeing the results.
Old Sep 21, 2012 | 09:47 AM
scorp508's Avatar
scorp508
In all the years I've never even heard of that intake let alone see it on an L98.
What is its power range supposed to be?
Old Sep 21, 2012 | 11:01 AM
THE 383 admiral's Avatar
THE 383 admiral
I wish this was out. when I purchased my HSR.. its a great intake from what I have read.. its a cross LT1 & HSR base, LT1 plenum, LS TB
This intake will most likely need more initial timing.. just like the HSR just starts to wake up @ 10* 12- 14 * hold on
I would get this combo tuned if I were you. Someone that has worked with the pro flow. To take full advantage. or learn & burn yourself is the best way. it takes a lot of log time to dial properly. keep us posted. Looks great
Old Sep 21, 2012 | 11:16 AM
Bandit's C4's Avatar
Bandit's C4
Central PA Events Coordinator
homina-homina-homina-homina [Jackie Gleason mod]
Simply go-jus....
Old Sep 21, 2012 | 01:26 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Nice!
Old Sep 21, 2012 | 01:30 PM
ch@0s's Avatar
ch@0s
It's fairly new. I tell you what its great to see a new product that fits under out hood. From what I understand you could pick up a used LS TB and use it with the Pro Flo making it an ever cheaper option.
Old Sep 21, 2012 | 01:56 PM
383vett's Avatar
383vett
Looks nice. Get going on the project. Spring is a long time. You should get it running by Sunday.
Old Sep 21, 2012 | 02:42 PM
Midnight 85
All donations are greatly appreciated. If getting it fired were the only thing it would be done by Sunday. Too many small parts left to buy yet.
Old Sep 21, 2012 | 02:44 PM
Midnight 85
1500 to 6500, almost perfect match to my cam's power band.
Old Sep 21, 2012 | 03:10 PM
cv67's Avatar
cv67
St. Jude Donor '05
Like how you did it up I bet you love it with that 383 will make substantial torque and wont die off once the fun begins. Faster all the way around!
Me thinks youll forget all about long tube runners.
Sure is easier to put on!!
black finish looks nice and clean
Old Sep 21, 2012 | 04:42 PM
AirForceOne!'s Avatar
AirForceOne!
Very nice! I'm going to replace my L98 with an LS-9 when it craps out!
To Bye Bye TPI
Old Sep 21, 2012 | 08:23 PM
Midnight 85
I'm going to get a PROM from PCMforless Which will be according to my mods, then I will get it dynoed locally & have PCM tweak it if it needs it.
Thanks to all you guys, I'm glad you like the setup and I hope I can give very favorable reviews on it.
Old Sep 21, 2012 | 09:15 PM
dclafleur's Avatar
dclafleur
Looks good!
Old Sep 21, 2012 | 10:01 PM
Midnight 85
Originally Posted by dclafleur
Looks good!
Thanks Dan, how have you been?
