700R4 output shaft
Old Sep 21, 2012 | 08:29 AM
topless92's Avatar
topless92
Default 700R4 output / tail shaft
I am starting a new thread as my problem was not my driven gear.
I installed a 37 tooth driven gear which should have worked with my red 17 tooth drive gear but it chewed it up. My original gear was a 36 tooth which is unavailable. Then I tried a 35 tooth with the same results. Both times I inspected the drive gear for defects and found none.
Next I checked for drive gear movement on the shaft and to my surprise the whole output shaft moved in and out, not side to side slop but in and out of the yoke. Is this normal? I would think not.
Is there a keeper or retaining ring on the shaft to keep from this kind of play.
I have scoured the shop manuals and have found nothing on this problem.
Any suggestions?
Old Sep 21, 2012 | 09:09 AM
topless92's Avatar
topless92
Default I found it
Retaining ring, output shaft to input carrier. But is this it? or is there normal play?
Old Sep 21, 2012 | 01:26 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Im looking for a website that was forwarded to me. The guy is in Hesparia, CA
He has a forum that he answers questions
Old Sep 21, 2012 | 11:24 PM
Cliff Harris's Avatar
Cliff Harris
That is Dana Wilkes and Probuilt automatics. I used his rebuild kit when I rebuilt my 700r4.
http://www.700r4l60e.com/forum/
Old Sep 22, 2012 | 02:17 AM
JrRifleCoach
Originally Posted by Cliff Harris
Old Sep 22, 2012 | 12:00 PM
topless92's Avatar
topless92
Default Thank's
Thank you for the link, I have posted and just waiting on the mediator to approve the post. I am thinking just to pull it and have it gone through this winter.
Scott
Old Sep 22, 2012 | 12:19 PM
JrRifleCoach
Please read my threads and select a good, known shop for the work....
To 700R4 output shaft
