No wipers
Old Sep 21, 2012 | 02:37 PM
1996man's Avatar
1996man
Default No wipers
My windshield wipers have stopped working on my 96. For those of you who have had this Happen to them, do I need to buy a new multifunction switch wand/stalk or the piece that sits in the steering colum. My cruise control no longer works either and stopped working at the same time. This makes me think it is the stalk. I wouldn't think both wiper motors themselves would go out at the same time.
Any Input?
Old Sep 21, 2012 | 04:30 PM
sailorsteve's Avatar
sailorsteve
At the risk of being a wiseguy (not the intent), have you checked the fuse?
Old Sep 21, 2012 | 05:47 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Mine was the stalk
They'd work if I'd raddle it around
Wound up replacing the whole column because of the tilt bushings
That problem also went away.
Old Sep 21, 2012 | 06:03 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
my 86 wipers quit working because the motor over travelled, and the crank, under the leaf screens in front of the windshield, struck the body, and the motor kept on running till it self destructed.
If you buy a new wiper motor, I would love to buy your black cap off your old wiper motor.
Old Sep 23, 2012 | 06:37 PM
1996man's Avatar
1996man
Guess I should have mentioned that yes, I did indeed check the fuse and it was good. replaced it anyway but with no luck. I guess the next step is to start taking things apart and see what is getting power and what isnt.
Coupeguy, if I end up having to replace the motor, you will be the first to know.
Old Sep 23, 2012 | 07:39 PM
blakngold4life's Avatar
blakngold4life
Mine quick after they had been intermittently working for a while. I put some contact cleaner on the connections and it has been fine ever since. A cheap fix before you start tearing things apart.
Old Sep 23, 2012 | 10:22 PM
csthews's Avatar
csthews
Oftentimes, the issue is in the cap. The FSM has list of checks to do to narrow it down before you start taking things apart.
Old Sep 24, 2012 | 12:00 AM
leesvet's Avatar
leesvet
yep...that cap is where ALL the magic happens...
use great caution if you decide to disassemble to repair or inspect. It has contacts inside that can fall apart or fall out and there really is not a good reference for putting all the pieces back together again..and the "cap" and its inerds are impossible to find.
Old Sep 25, 2012 | 12:36 AM
Phat98's Avatar
Phat98
Only one motor per customer. please....
Old Sep 25, 2012 | 01:53 PM
1996man's Avatar
1996man
Pardon my ignorance but what cap exactly are you talking about?
To No wipers
