Cam question.
Old Sep 25, 2012 | 11:06 PM
_Vette_'s Avatar
_Vette_
Default Cam question.
On a stock 85 corvette, whats the cam size, and whats the biggest I could go without changing anything? Im wanting a 279.
Old Sep 25, 2012 | 11:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
279 what? Got a pn?
Big cams usually dont play well with TPIs.
Cam a TPI the opposite of how you would cam a carbed motor.
Think small
Old Sep 26, 2012 | 12:01 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
OTOH, that's the adv duration for a HOTCAM IIRC.
Old Sep 26, 2012 | 12:30 AM
_Vette_'s Avatar
_Vette_
Whatever this guy has, I love the sound of it. And it sounds big, but I know a smaller one would be better. I want something slightly larger than stock that will go in without many changes. What should I get?
http://www.youtube.com/watch?v=MOOJIk3BbGs
Old Sep 26, 2012 | 09:13 AM
as long as it is red's Avatar
Your L98 is built for torque. A good cam choice to add to what the engine is already making is Howards Cams # 180225-12. It is a retro roller.
Intake C/L is 108
The lobe center is 112 - I .450 @ 260 duration, E .465 @ 266 duration.
TPI needs @ 112 or more to be streetable if you run the AC and factory tune.
This cam pulls hard from 800 - 4800 RPM. After that you will need more air - intake. You might even see 1 -2 mpg gain. TBI trucks do.
You might meed a new distributor gear with the cam swap. Get the correct one for a roller cam. Get the "correct for the cam" NEW lifters too.
Make sure the car is tuned up and running at it's best before you do any mods. There are so many variables. Bigger is not always the way to go in a cam selection for a street car.
Old Sep 26, 2012 | 11:24 AM
cv67's Avatar
cv67
St. Jude Donor '05
If you want it to sound cool (and not much else) go for it.
If you want it to run hard read the above post.(#5)
Old Sep 26, 2012 | 12:19 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I'm running CompCams #12-238-2 XE262H-10 int 262/.462 ext 270/.469 sep 110 with their 1.6 roller tip rockers and springs/retainers.
All this fits under the factory valve covers without any modifications.
The result is a solid power gain and much better sound.
Old Sep 26, 2012 | 01:04 PM
76z28's Avatar
76z28
I'll be running an edelbrok rolling thunder cam in my 383 it's in the middle of an LT1 cam and the lt4 hot cam
Old Sep 26, 2012 | 01:22 PM
ch@0s's Avatar
ch@0s
What ever you do don't get a cam from Ebay. I got one from an Ebay member that sells LT$ hot cam and CC502 knockoffs and ended up with a paperweight for a motor.... willhoites cams
Old Sep 26, 2012 | 06:44 PM
JohnTVette's Avatar
JohnTVette
nasty! When did that happen?
Old Sep 26, 2012 | 06:55 PM
ch@0s's Avatar
ch@0s
I bought it several years ago it was the first mod I did.It went about 1k before it took my bearings out. It was the reason why I went LSx it was either rebuild or swap and after weighing the cost I went with the swap.
Old Sep 26, 2012 | 07:42 PM
JohnTVette's Avatar
JohnTVette
that is just an odd looking failure. It looks like something gouged it.
Old Sep 26, 2012 | 07:46 PM
76z28's Avatar
76z28
Seriously! Looks like a welded cam they reground(heard of them but never thought it was true) and broke a chip out at the weld
Old Sep 26, 2012 | 07:47 PM
76z28's Avatar
76z28
Kinda of wish I could have went lsx swap but the budget wouldn't allow for that :P
Old Sep 26, 2012 | 07:53 PM
ch@0s's Avatar
ch@0s
Yup, close up you can see it better and it looks just like you said. It was more that one lobe it happened on like 4 of them and took out my bearings.
Old Sep 26, 2012 | 07:56 PM
76z28's Avatar
76z28
4?? Dang I wonder how it even broke like that
Old Sep 26, 2012 | 08:05 PM
ch@0s's Avatar
ch@0s
From what I have been told Its a problem with the hardening process. In person you can tell it slowly wore small chunks of the weld out and into my oil.
To Cam question.
Old Sep 27, 2012 | 11:29 AM
JohnTVette's Avatar
JohnTVette
Man, that is just insane. Did they take any responsibility for it?
Old Sep 27, 2012 | 01:01 PM
ch@0s's Avatar
ch@0s
They said it only had a 90 day warranty. They did ask me to send the cam in so they could take a look at it but argued that what I was saying was impossible. I didn't send it to them I got the feeling if anything I was going to get just another crappy cam that may or may not blow up my next engine.
Old Sep 27, 2012 | 01:27 PM
JrRifleCoach
Where's the OP?
