Shock rattle
Old Jun 3, 2002 | 11:07 AM
rats87's Avatar
rats87
Default Shock rattle
Since I bought my car I have been trying to locate a nasty rattle in my rear right wheel well. Now I have found that the upper bracket that holds my shock in place is pulling away from the body. Has anyone else ever heard of this problem?
Old Jun 3, 2002 | 01:27 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Shock rattle (rats87)
Are both bolts present. It should be 13mm bolts going up into the frame of the car that holds the shock in place.
Old Jun 3, 2002 | 03:46 PM
rats87's Avatar
rats87
Default Re: Shock rattle (Jeffvette)
I did see a small rubber nub, but unless there is a bolt under it there are none. Maybe I should actually pull off the other tire to compare instead of being lazy. :)
To Shock rattle
