Digital Dash ground problem
Old Sep 26, 2012 | 09:56 PM
Z52 VETTE's Avatar
Z52 VETTE
Default Digital Dash ground problem
I posted earlier on the dash. Like I said its rebuilt and everything is hooked up right. Long story short it still goes on and off so i assume its a ground somewhere. Does anyone have an idea of where i could find this ground..rumor its near the bell housing? I HAVE NO IDEA HAHA. Any help would be much appreciated
Old Sep 27, 2012 | 12:07 AM
leesvet's Avatar
leesvet
its on the bellhousing.
why would you think that to be inaccurate? grounds often go to big chunks of iron or steel.
or
the side of the block.
no bs. Its on the bellhousing,.GM put them in both spots. Fairly easy to ID...look for the stack of several black 12 &14g wires stacked on 1 bolt.
Old Sep 27, 2012 | 12:45 AM
Z52 VETTE's Avatar
Z52 VETTE
or
I really appreciate it. and because ive heard rumors of them getting brittle and disconnecting fairly easily. im hoping maybe to re ground that and it will work good. Idk,, we ll see, any other input from anyone else is accepted, and thank you again lee
Old Sep 28, 2012 | 08:12 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Default another ground point - driver side outer kick panel
Also check behind the 'kick' panel, by your left foot.
Important ground point and given its location, likely associated with dash.
To Digital Dash ground problem
