Wheel interchangeability
Old Sep 27, 2012 | 04:47 PM
mmcgue's Avatar
mmcgue
Default Wheel interchangeability
I have a stock '95 LT1. This has the 8.5" wide front rims. Is there any problem caused by mounting the 9.5" wide Z07/ Pace Car rims on the front of mine. Will they even fit?
Thanks folks!
Mike
Old Sep 27, 2012 | 05:09 PM
94z07fx3's Avatar
94z07fx3
No problem. Yes, they fit. And if you have 17x9.5 on all four corners you can rotate front to rear.
Old Sep 27, 2012 | 05:10 PM
mmcgue's Avatar
mmcgue
Thanks!
Mike
Old Sep 27, 2012 | 09:51 PM
rodj's Avatar
rodj
Earlier cars have 9.5" with 275/40's on all four corners.
http://www.joby.se/corvette/div/corvette_wheels/
GM went to the narrower rim and 255/45 tire in '93 apparently because of owner complaints about the wide fronts tracking in road grooves
Old Sep 28, 2012 | 05:17 AM
gerardvg's Avatar
gerardvg
[QUOTE/]GM went to the narrower rim and 255/45 tire in '93 apparently because of owner complaints about the wide fronts tracking in road grooves[/QUOTE]
Yes that can be an issue if you run low tire pressures like 30 psi, 35 or 38 psi all but eliminates the tracking issues.
I have 275/40/17 all round and the car is very well behaved even on uneven road contours.
Old Oct 5, 2012 | 11:18 AM
dchildress's Avatar
dchildress
My 94 has 275/40 -17 tires wrapped around 17 x9.5 wheels and has been lowered 1.5 inches. I have very, very little rubbing on my inner front fenders from having wheel turned all the way and bottoming out. Nothing to worry about though at all.
To Wheel interchangeability
