Estimated quarter mile Time
Its an 87 corvette z52.
Engine: 383ci- all forged bottom end, scat crank..10 to 1 compression rated pistons, arp 500 hp rated push rods i believe, stock L98 heads, but machined and with new valves spings etc. motor works .482/.500 lift roller camshaft. all new high rpm roller lifters. double roller timing chain, With duel tensioners for max RPM rate. INtake wise,edlebrokhigh flow ported based, ported TPI runners..58 mm throttle body, custom flow air intake system..MAF removed...160 degree thermostat...exhaust wise..gutted stock manifolds...follwed by 2.5 inch FUll exhaust, no cat,,flo pro 150cfm mufflers. also 24 lb rated injectors
Rear end- corvette performance 3.07 gears
Transmission-tuned 700r4
Tune- The car was completly dyno tuned at a shop, everything is in sync with the 383. Rated at 363 hp...410ft pds of torque. No estimated quarter mile was given.
Anyother questions lemme know. Look forward too hearing predictions
12.19 @ 111mph based on 3400lbs
1/4 Mile Calculator click here
You need a sticky tire to take advantage otherwise youll just go up in smoke.
http://www.summitracing.com/search/B.../?autoview=SKU
Last time I went to the track, I was running 275 Faulkins. Bone stock
LT4. 13.5 @ 107 mph. Spun all through 1st and 2nd, almost sideways for a second. More controlled launches resulted in higher e.t.'s but trap speeds of 108 & 109. I was a rookie w/ the 6spd then. Haven't been back to the track since. Closed KCIR and Topeka seems a bit of a haul. As in I would hate to pay that tow bill if something broke.
For the amount of fun youll have thats cheap.
just go, used to drive almost 2 hrs ea way to race the Z then go back home. h.
Is the A4 stock, i.e. shift kit and/or hi-stall TC??
In any case, arrive with 1/3 tank of fuel, drop rear inflation to 30psi.
If you don't have a fan switch or reprogrammed ECM, open the small connector in the A/C pressure line to bring on the main fan.
Avoid the water box, do a short dry hop before pre-staging, When staging, line up in the dark rubber tracks of prior slick tire cars.
When you launch, on the 3rd yellow roll into the throttle to get a good hook. Mash it and you will go up in smoke.
Have fun and enjoy; playing at the strip will be a whole new experience and can become addictive...
Come on out to HPT. I would love to see some more C4 brothers come out. The staff at HPT is very welcoming and will help out the new faces. You still have time this season to hit some test and tunes. I bet after a couple of those you will get the competition bug and come out for an E.T. bracket race. The last race of the season is a two day race 10/27 and 10/28. The Trophy class is a perfect place to get started, foot brake and 12.0 sec. fastest dial.
P.S. RIP KCIR. Don't get me started on that subject.
Come on out to HPT. I would love to see some more C4 brothers come out. The staff at HPT is very welcoming and will help out the new faces. You still have time this season to hit some test and tunes. I bet after a couple of those you will get the competition bug and come out for an for an E.T. bracket race. The last race of the season is a two day race 10/27 and 10/28. The Trophy class is a perfect place to get started, foot brake and 12.0 sec. fastest dial.
Yeah, the whole KCIR thing is...well...you know. I am would really love to see a track of HPT quality out at the Legends near the Speedway. Suprised it's not in the works yet. If I win the lottery, I'll build one.
Just can't replace the feeling of full on acceleration on a sanctioned drag strip.
http://forums.corvetteforum.com/c4-t...w-383-tpi.html
