MAF Relays??
Old Sep 28, 2012 | 10:58 PM
rrt898's Avatar
rrt898
Default MAF Relays??
I have 1986 coupe. I know the location of the two relays behind the battery. My question is which one is the burnoff relay?? Also does anyone have the correct part numbers for both? The local parts store wanted to sell me two of the same relays and I thought that wasn't right.
Thanks.
Old Sep 28, 2012 | 11:30 PM
joeld's Avatar
joeld
On a 89 the burn-off relay has 4 wires: 2 orange,1 dark blue,1 black.
The power relay has 5 wires.
On mine the burn-off relay is inboard: closer to engine.
Also on mine the relays are the same, not 100% sure on 86 but thinking they are.
Joel
Old Sep 29, 2012 | 12:45 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
un plug one of them, if it runs, it was the burnoff relay
Old Sep 30, 2012 | 12:04 AM
leesvet's Avatar
leesvet
its right.
Old Sep 30, 2012 | 03:23 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You are correct; on '85-'87 Vette the BO relay differs from the Power relay but is the same as the fuel pump relay.
Same setup on my '88; I recently had to replace the BO relay.
Old Sep 30, 2012 | 09:07 AM
leesvet's Avatar
leesvet
Odd.
on MY '87 the power & burn-off are the same. Fuel pump is similar (5-pins inline)to the 2 fan relays that are rectangular not semi-square like MAF relays.(4 & 5 pins square pattern)
Some of you are looking at trans relays and/or fans.
Remember that in 85 or 86 (IIRC) there is a MAF module inside, NOT a set of relays. You may be looking at something besides MAF relays..
FWIW..
the burn-off has nothing to do with how the engine runs. Its more of an automated maint item, not a control device.
Old Sep 30, 2012 | 10:08 AM
tunedport85inject's Avatar
tunedport85inject
Originally Posted by leesvet
Odd.
burn off relais only heat for some seconds the light maf wire to clean it ,the power relais is fuctional.
Maf module for the 85' is a rare and expensive device
i know it i have an 85...
Old Sep 30, 2012 | 02:28 PM
65Z01's Avatar
65Z01
Hmmm, interesting; I got that '85-'87 info from my TPIS parts catalog???
Old Sep 30, 2012 | 04:04 PM
leesvet's Avatar
leesvet
most aftermarket catalogs do not contain the subtle differences between one yr model and the next.
relays, master cylinders, coolant sensor locations (swapped a cpl yrs)...even the odd ball MAP system is often missed by the catalogs.
Thats what makes the FSM so beneficial, BUT, limited to the one yr that it covers...accurate but narrow.
Old Oct 1, 2012 | 02:43 AM
Cliff Harris's Avatar
Cliff Harris
The '86 was the only year that had different MAF power and burnoff relays. The correct part numbers are:
10094701 -- MAF burnoff relay
10067925 -- MAF power relay
You can cross-reference these numbers to generic parts.
The relays are different internally and you can't swap them, even though the connectors are the same. The car WILL run with the relays swapped, but you will not get MAF burnoff and the MAF will eventually get dirty and your car will run really badly (you don't need to ask how I know this...)
Old Oct 1, 2012 | 06:59 PM
rrt898's Avatar
rrt898
Default Relays
Thanks....I had a feeling when I was offered the same relays for both. I knew I had to check it out further. Thanks again for the part numbers.
Old Oct 1, 2012 | 08:35 PM
leesvet's Avatar
leesvet
as previously stated, more often than not it is a relay thats throwing a MAF code and not the MAF itself.
These MAfs are pretty durable if they have not been modified. Even though the wire type is fragile in the respect that anything that gets sucked thru WILL wipe out the wire element, they hold up very well if the screens are still there to protect them. I've transplanted the 'core' with the heat-sinks and wire to other tubes or bodies, and had them survive the trauma.
The relays on the other hand get wet and they short or the corrosion gets inside and the delicate nano-thin wire gets broken very easily. A good bump will break one.
I wish I had $10 for every good MAF thats been replaced when it was only a relay that had failed...
Old Oct 1, 2012 | 08:55 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Power relay is behind the Burnoff relay on my 86e
To MAF Relays??
