Rear sway bar
Sep 29, 2012 | 08:31 AM
Rear sway bar
Can someone please post a pic of there rear sway bar?
I can't remember how it goes back on the car
Can't remember if the ends curve up or down.
Sep 29, 2012 | 08:49 AM
Sep 29, 2012 | 09:09 AM
You'll need to overlook some of the suspension modifications but maybe this perspective will help you!
Sep 29, 2012 | 09:13 AM
Quote:
Originally Posted by
vetteoz
WOW ! That's a great looking rear suspension unit.
WELL DONE !: cheers:
Sep 29, 2012 | 10:11 AM
I gave that bearing some racing modification. Much better cooling!
Sep 29, 2012 | 10:16 AM
Thanks for the replies.
I think that the ends curve up.
Sep 29, 2012 | 10:17 AM
Aardwolf
What bearing??
Pics??
Sep 29, 2012 | 10:19 AM
O the wheel bearing..
How did u do it?
Sep 29, 2012 | 10:24 AM
The ends curve up yes. I remember putting it the other way one time trying to get the end links to fit better. The bar hit the frame, the bolted on part behind the end link. It's possible to clearance it but better just to run it like shown.
The bearing failed from track abuse.
Sep 29, 2012 | 10:30 AM
Racing is all I do with the car.
What mods did u do to the bearing to help it cool.
I do worry about failure at the speeds that I run 135+ on the straights.
Sep 29, 2012 | 10:35 AM
I was making a joke, it fell apart and can get some cooling air now.
They typically give a good amount of warning before going bad.
Sep 29, 2012 | 10:48 AM
Aardwolf
Copy
