kwiklift users
Old Oct 1, 2012 | 07:48 AM
93 ragtop's Avatar
93 ragtop
Default kwiklift users
What are you using for a transmission jack? I have used this in the past, but it dosnt go high enough when the car is on the kwiklift. http://www.harborfreight.com/450-lb-...ack-39178.html
Seems I need something that goes up 36 in. or so. But would be a low profile to slide out from under the car with the transmission on it.
Old Oct 1, 2012 | 08:21 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I built a platform to put on top of the jack and it worked fine.
Old Oct 1, 2012 | 08:04 PM
SJW's Avatar
SJW
I have used this one to R&R the ZF-6 gearbox on my '94 for clutch/flywheel/etc:
http://www.harborfreight.com/automot...jack-3185.html
It worked fine, BUT it would not drop low enough to allow me to roll the jack & transmission out from under the car. It wouldn't clear the Kwiklift's ramps on either side, and it wouldn't clear the Kwiklift's jacking cross-pipe to the rear. And, to the front, it wouldn't clear the Kwiklift cross-bridge I was using to support the jack I was using to keep the rear of the engine from dropping. So it was trapped under the car, and I had to work around it, which was a significant PITA. It goes high enough, but not as low as I'd have wanted.
Live well,
SJW
Old Oct 2, 2012 | 07:52 AM
93 ragtop's Avatar
93 ragtop
The problem with adding the platform has been stability, and no way to roll it out from under the car. I have to seperate the jack from the transmission to get it out from under the kwiklift. And worse is putting it back by myself. Talk about a wrestleing match I think im going to loose!!
Old Oct 2, 2012 | 07:57 AM
93 ragtop's Avatar
93 ragtop
Live well,
SJW
I looked at that one, but it says it goes up to 24 inches. When measuring mine, (automatic) I need at least 27 in. I would love to find one that would go 30-36in. so I could use it with other vehicles as well. We have a harbor freight store about 13 miles from my home. I will drive by and measure just how high it does go. Could be a misprint on their part or as high as they rate it safely.
Old Oct 2, 2012 | 08:14 AM
SJW's Avatar
SJW
Originally Posted by 93 ragtop
[/B]
It's worth checking the true height on the one in the store. I can't imagine the published height of lift is a safety issue. This one is inherently far more stable than the scissor unit you've been looking at. It has a pretty large footprint. It would take some talent to capsize it even with a heavy trans sitting at full-lift height. Good luck with the search. Maybe you could lower the car 3" by letting the air out of the tires.
Live well,
SJW
Old Oct 2, 2012 | 11:10 AM
Dynomite's Avatar
Dynomite
You need the 800 lb capacity Harbor Freight Transmission Jack and the 3 Ton Capacity Harbor Freight Aluminum Floor Jack
ZR-1 Transmission Install and Lift Tricks
To kwiklift users
