'89 HEADLIGHTS NOT WORKING PROPERLY!
Old Jun 3, 2002 | 06:49 PM
hotinphx's Avatar
hotinphx
8th Gear
Default '89 HEADLIGHTS NOT WORKING PROPERLY!
I have a problem with my headlights. The right motor flips up the lamp, but the motor continues to whirr for 3-4 sec. The left motor only flips up the lamp half way and the motor does not continue to run. What do I do? :confused:
scorp508's Avatar
scorp508
Replace the worn out bushings. :yesnod:
Old Jun 3, 2002 | 09:53 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
Default Re: '89 HEADLIGHTS NOT WORKING PROPERLY! (hotinphx)
You can buy the bushings at Ecklers or any other Corvette place. I had to chang mine. I have an 89 Vette. The head light would go almost all the way and then drop down. Sure enough, It was the bushings. Most places charge $10.00 for two sets, So you are able to do both sides. The job was time consuming since I never did it before. I took my time so I would not break anything.
Old Jun 3, 2002 | 09:59 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: '89 HEADLIGHTS NOT WORKING PROPERLY! (89NYFINESTVETTE)
yep, replace those darned bushings. Its easy to do and cheap.
:seeya
Old Jun 3, 2002 | 10:01 PM
RonsRed88's Avatar
RonsRed88
Definitely the bushings. I used the directions in tech tips and didn't have any problems. https://www.corvetteforum.com/techti...D=16&TopicID=2
Ron
To '89 HEADLIGHTS NOT WORKING PROPERLY!
