mat sensor help
Old Oct 7, 2012 | 10:57 AM
1989erniew's Avatar
1989erniew
Default mat sensor help
i just replaced my injectors when i removed the the induction system i unplugged the mat sensor now i do not remember where the plug plugs to harness????anybody got pics or info??? thank you!!!!!!!!!!!!!!!!!!!!
Old Oct 7, 2012 | 11:12 AM
Matatk's Avatar
Matatk
The sensor is on the bottom of the plenum, mounted vertically near the rear. If you didn't plug it in when the plenum was off it's a PIA. I made that mistake once and was able to connect it with a long screwdriver and a pair of long handled needle nose pliers. But it wasn't easy.
Good luck,
Matthew
Old Oct 7, 2012 | 11:20 AM
1989erniew's Avatar
1989erniew
Default thank you
Good luck,
Matthew
thank you very much i unplugged the wire at both ends i can not remember where it plugs to harness from sensor????
Old Oct 7, 2012 | 11:21 AM
1989erniew's Avatar
1989erniew
thank you......
Old Oct 7, 2012 | 11:33 AM
Matatk's Avatar
Matatk
It connects by the firewall in the rear area behind the distributor.
Old Oct 7, 2012 | 11:49 AM
1989erniew's Avatar
1989erniew
Default mat sensor
thank you very much i will look behind distributor.......thanks for quick reply
Old Oct 7, 2012 | 11:07 PM
Cliff Harris's Avatar
Cliff Harris
The connector is behind the head on the driver's side. It's part of the very large engine control harness that goes to the ECM.
To mat sensor help
