please help rear impact
Old Oct 8, 2012 | 06:03 PM
airbrush guy's Avatar
airbrush guy
1st Gear
Default please help rear impact
had a rear impact with my 85 targa it hit so hard broke steering column with my body , now turn key on get no dash n no starter headlights etc work but nothing else are there rear impact sensors or something in steering column i should be tackling any help would be awesome thank you
Old Oct 8, 2012 | 06:17 PM
1986coupe's Avatar
1986coupe
No sensors of that kind back then. Sounds like you need to have the car thoroughly checked over. Make sure the frame hasn't been bent.
You can probably just replace the steering column with a known good one.
What did your insurance company report on the accident?
Old Oct 8, 2012 | 07:08 PM
JackDidley's Avatar
JackDidley
When you turn the key, it moves a rod that operates a switch down lower on the column. That rod is probably bent or knocked out of the switch.
Old Oct 9, 2012 | 12:10 AM
gerardvg's Avatar
gerardvg
I agree with Jack
The ignition switch pushes a rod on the steering column to a switch, if that had moved slightly you wont be able to start the car. the switch is under the dash on top of your column, easy to find loosen the screws and side it up or down slightly.
Hope she is not badly damaged and repairable
To please help rear impact
