Engine Oil Change Time
Old Oct 9, 2012 | 06:45 PM
Paul the Brit's Avatar
Paul the Brit
Cruising
Default Engine Oil Change Time
I have a 96 C4 (P) 5.7L How much Engine Oil should I purchase, and what grade (I live in Central CA).
or
I was thinking of using Synthetic, but have read for an older engine (mine has done 88K) it's not good, as it's 'thinner' and could 'leak' out??
Thank you in advance for your assistance with this
Old Oct 9, 2012 | 07:53 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Synthetic 10-30. About 4 1/2 quarts. And get a good filter like Mobil #M1-201
Old Oct 11, 2012 | 12:09 AM
1986coupe's Avatar
1986coupe
Synthetic oil doesn't gum up like dyno oil. I use sythetic in my L98 and have for 10 years. It transfers heat better (remember oil not only lubricates but also transfers heat away from parts, aiding in the cooling process)
Old Oct 11, 2012 | 01:32 AM
Phat98's Avatar
Phat98
Your oil fill cap should say Mobil 1, SAE 5W-30. Use it unless you're really abusing that motor...that's what was in it when it left Bowling Green. 5 quarts, you can buy the jug @ Wal Mart and save a few bucks. I use an AC PF52 oil filter on both my C4s, no problems...just remember to fill the filter with oil before you install it.
88K miles, your engine is just now good and broke in...my '94 has over 151K, motor has never been torn down, and chirps the tires on a 1-2 shift when you're floorboardin' it.
Old Oct 11, 2012 | 12:14 PM
Paul the Brit
Cruising
Default Thank you
I appreciate your input, thank you. Just looked at your Vette, NICE
Old Oct 11, 2012 | 12:19 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
This is what I use in my street vehicles, as well as my Vette when it was on the street.
http://kahunamotorsports.com/asl-product-page.html
Synthetic oil is not thinner and will not make you engine leak. What happens is when the conventional oil breaks down, or collects dirt, it becomes like sludge or tar. This sticks in the corners and gasket areas of the engine, and could potentially block a leak in the gasket from actually leaking. When you switch to synthetic the detergents and dispersents in it clean out the old sludge and debris from the conventional oil. If there was a leak there already and you clean the sludge from blocking it, there will be a leak, but synthetic oil will not cause any leaks.
Old Oct 11, 2012 | 12:22 PM
Paul the Brit
Cruising
Default Thank you
Thank you for your assistance....I'm 'new' to Corvettes, as you can probably tell, lol
Old Oct 11, 2012 | 12:23 PM
Kubs's Avatar
Kubs
That's why we are here!
To Engine Oil Change Time
