FRAME BRACES: How many interested?
Side note, how many people want camber braces? I have the RD engineering design on my car and it would not be difficult to make a chromoly version. It's a simple product, so price would be very reasonable.
Thanks,
Brandon
www.riceperformanceproducts.com
So why not reinforce the unibody and make it last longer, in addition to getting more stiffness? Here is an example of reinforcement welded to the unibody rail of a Jeep XJ. But I think you could get just as good results by epoxying something like this to the framerail.
You can also tie parts of the frame together with a rigid frame, instead of just tying them together with tension rods. Check out the Miata Butterfly Brace:
http://www.flyinmiata.com/index.php?...umber=13-69920
It seems like something like the butterfly would also act as a skid plate and protect the exhaust piping etc. Also the stresses are distributed better than with just 4 mounting points like an X brace. They also sell the framerail portion of the butterfly separately. Same idea as the Jeep one http://www.flyinmiata.com/index.php?...umber=13-69010
I finished the basic prototype this last weekend and I started making some drawings. I am looking into availability of Chromoly tubing to determine the final design for the prototype. I intend to make 1 prototype and install on my car for initial fitment and measurements. After that I will email those of you that are interested in testing for the first 10 sets. I should have a good price estimate in the next 3-4 weeks. Since I am already past 10 on my initial testing list, I will let everyone know now that I plan on offering a group purchase for the next 10-20 people that are interested. I may make the list slightly longer depending on the discount I can get on production.
Here is a picture of the basic design in 2d. I am currently working on the CAD model for production. It will probably change slightly after the prototype.
I decided to make the connection for the x-brace near the front because it had the least affect on ground clearance due to the exhaust.
Since the x brace members are in tension most of the time they could be made much lighter than if they were in compression how much lighter I don't know, I'm not an engineer. I am also interested in the design you are working on, good luck.
-Aluminum: Light weight, but I am not sure if it can handle the constant abuse that the system may be subjected to.
-Mild Steel: Excellent strength and cost effective but heavy
-Chromoly Steel: Very strong and about 30% Weight savings over mild steel
-Titanium: Light weight and very stong, but also very expensive
I am initially leaning towards Mild Steel or Chromoly Steel(with black powdercoat of course).
Since the design would be the same (except for wall thickness),
and the jigs would be the same, have you considered doing both
mild and chromoly, with, say, a $100 price difference?
I never drive my '87 with the top off, I'm not personally interested,
just tossing out an idea that might be helpful.
Chuck
Also if the braces get too thin they'll just buckle in compression. (During twist one is in compression). So you are either relying completely on the other one in tension, or you have a significant vertical dimension in the braces at the expense of ground clearance.
As far as the side braces, I plan on doing a few simple tests on my car with the prototype to determine effectiveness of each brace section.
Thanks,
Brandon
The problem I have with all forms of X-brace is the basically only work in 1 plane as generally an inch tall or less and lots of bolted joints to flex. They are certainly better than doing nothing and doing the tunnel is not a brace it is a major fabrication project no doubt well beyond the scope of most for a street car and might make it no legal for some race cars.
My take on it all anyway..
Thanks,
Brandon
Thanks,
Brandon
You have more time under the car than me as mine was only to install new exhaust on jackstands and very happy to be done and did not linger there on my back wonder what if. I have seen frame pics here I am sure and remember it showing front floor pan and part of the firewall as steel. If there was a way to tie that steel to across the B pillars I would think it would add a ton of stiffness. I wonder if you put a bar across the rear monts of the X and then tied that into the B pillars what you might get.
http://www.waxner.com/?tag=lotus-elan-1962
Here is a link to a book that might cut the R&D time way down and provide easy ways to test if you are making an improvement and how much. Something I would bet most have done by seat of pants rather than real engineering and testing otherwise they would advertize the old and new deflection rates.
http://books.sae.org/book-pt-90
I won't argue with you here. Go find out for yourself from the man himself, Chief Engineer Dave McLellan. Corvette from the Inside, I own a copy.
Your chassis ideas are not NEW at all. Dave wanted to do a lot of stuff on the C4 that was later on the C5. Some of your comments are things Dave wanted to do. GM Management, as usual, F-ed things up.
If you have read the book why not enlighten everyone that has not might be the real question.....
The center spine is basically the C-beam as it eliminates the space eating cross member of the C3. Dave liked the driveline of the Porsche 928 with its torque tube and rear mounted transmission. However, they could not afford the rear mounted transmission. That came later a la C5.
Originally had a torque tube a la C5. However, they had a drive line vibration with that the best solution was to open up the tube (C-beam) and vibration out of driving range of engine RPM. Also this allowed for a conventional prop shaft. Unlike the C5 and up, drive line service does NOT require a complete tear down from the rear.
A lot of time and testing went into the chassis even using a Grumman Aircraft state of the art CRAY computer for simulations and finite element analysis. Dave says that even with all that they did not predict the hinge like nature of the transitions between 2 rail and 3 rail structures. Thus they did not predict the stiffness of the chassis well at all.
GM Lloyd Reuss "requested" (McLellan's type) that the car be a targa. All that time/effort on the structure was for nil without the t-top.
They added the high door sills, still too flexible, added reinforcements where it was moving the most. They got the chassis to be just above wheel hop frequency with the top on. Wheel hop frequency in a C4 is 14.5. Structure stiffness is about 17hz. Compared to the 21hz of the C5 with the TOP out. With the Top out in a C4, the chassis flexes below that of wheel hop so it shakes a lot. The reason wheel hop is important is that it is the "highest frequency of road input."
In the late 80's Dave asked Lotus how they might do a Corvette structure. Backbone, center tunnel is the answer to front engine rear drive. The C5 structure was built from the ground up to be stiff, the hydro forming has a lot to do with this, as does the center tunnel design.
Long story short, the C4 is a flawed chassis design due to GM management interference in something they didn't understand.
NO amount of bracing will significantly increase the stiffness of the structure, there is NO way to easily create a center tunnel for the drive line to run thru and to hold the car together.
If there had been a practical cost effective way to do this, don't you think they may have pursued it? Rumor is Vette to Vette's tension rods are Gordon Kilebrew designed as he? discovered the metal was flexing about the spot welds. However, it was so late in the C4's development cycle it was not cost effective to make any changes.
The only reason the C4 is a good handling car is that the suspension is very well designed for the time. Its obsolete compared to the C5 and up, but still a good design.
You really need to read the book to get a complete picture.
There are loads of pics on the net that shows the floor pan and tunnel being two piece rather than a rigid tunnel. It makes me wonder if the fix is on the inside. If you bonded aluminum honey comb to the existing floor pan and then a layer of either fiber glass or carbon fiber to that to make it all one piece and structural from firewall to rear bulkhead and cover those as well. It would not be thick and not add very much weight either.
In the end anything done needs to be tested and there are simple ways to do it given a little bit of work.
