I think it's radiator cleaning time
Old Jun 4, 2002 | 06:17 PM
GlockLT4's Avatar
GlockLT4
Default I think it's radiator cleaning time
It's 90 degrees, out right now. Humidity makes it 94.
Driving around for a while, i hit 237*F Coolant and 249*F oil. Time to get her down to 220 or less. The A/C on causes my engine to get sooo much hotter. I turned the A/C off for part of the drive home from errands and I noticed that my coolant temp dropped fairly quickly to about 215-220. I would prefer to never see over 200 if I had the option.
Any other recommendations besides cleaning my radiator, and adding water wetter?
I'm about to consider those fans that pump heat from the engine bay to the wheel well area, but what's holding me back from that doing is that it will heat up my brakes even more.
I have my fans programmed to turn on at 204 and off at 194. I'm going to program them to come on at 180 next time I reprogram.
[Modified by Glock'94, 10:57 PM 6/4/2002]
Old Jun 4, 2002 | 10:37 PM
R23HTC's Avatar
R23HTC
Default Re: I think it's radiator cleaning time (Glock'94)
That's kind of strange. When you turn the A/C on your automatically kick all the fans on. I've seen my temps go DOWN with the A/C on. Are you sure the fans aren't going bad. I remember you saying one had been squealling. :rolleyes:
Old Jun 4, 2002 | 11:50 PM
vader86's Avatar
vader86
it does sound weird, did you set the fans to come on earlier while you were tuning it?
Old Jun 4, 2002 | 11:57 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
What does temperature do on highway at speed around 60 - 70 mph constant? Where does it settle out after 15 or 20 minutes?
Same question with AC on and AC off.
If left to just idle in the driveway, where does the temperature go?
Same question AC on and AC off.
Do you remember what mix of anti-freeze and water you have, i.e. 50/50, 60/40 ?
Stock pump or high flow pump? Thermostat temp rating, and is it a high flow thermostat?
Old Jun 5, 2002 | 12:04 AM
Denney's Avatar
Denney
Curtis, I was having the same problem on my 94 until this past weekend when I replaced the intake manifold gasket, water pump, and radiator (and plug wires and belt). I wasn't sure what (or which) was causing the problem so, rather than take a chance on any one of them, I did them all. The results were outstanding! I have not gone over 186 F since (and that was with the A/C off). My primary fan is programmed to come on at 184 F so a small overshoot was expected. I tested the fix with A/C on max, stop and go traffic, with outside temp around 85 and it was solid at about 182 F. Not that I am recommending all of them to you, but it worked outstandingly for me. And I have 107k miles on mine. HTH
Old Jun 5, 2002 | 12:05 AM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: I think it's radiator cleaning time (PeteL)
Just to let you know, I pulled my radiator on Saturday, bent a bunch of the fins back to where they were supposed to be, and picked out a BUNCH of crap between the fins. I reinstalled the radiator, then drained my system, and ran distilled water through it, until it came out clear.. I then added a cooling system cleaner, and ran it through the car for 15 mintues. Drained again, and ran a bunch more distilled water through it.. Then I filled it up with about 35% antifreeze, 65% distilled water, and a bottle of water wetter..
My crusing temp went down from the 220 region, to around 200.. and my idle temp went from 225-240 or so, down to 205-215.. It mad a HUGE difference!!! :)
Old Jun 5, 2002 | 12:20 AM
GlockLT4's Avatar
GlockLT4
Default Re: I think it's radiator cleaning time (R94 LT 1)
Both of my fans turn on at 204*. I'm going to be changing this to 180 next time i program my car.
Old Jun 5, 2002 | 12:21 AM
GlockLT4's Avatar
GlockLT4
Default Re: I think it's radiator cleaning time (MarkLT1)
:cool: that's what i'm looking for
Old Jun 5, 2002 | 12:24 AM
R23HTC's Avatar
R23HTC
That'll probably help also! :cheers:
Old Jun 5, 2002 | 12:59 AM
GlockLT4's Avatar
GlockLT4
Default Re: I think it's radiator cleaning time (Denney)
The radiator is the only one there i see that would help with engine temps. Glad it helped you! :cheers:
Old Jun 5, 2002 | 01:57 AM
Rich_01659's Avatar
Rich_01659
i have a wierd home brew fan switch which came with a thermostat, i can set it to come on at any temp, just pop the hood and turn the ****. my point is if your heating up after the fans come on, it will not help to have them come on sooner. I've tried the lower temp settings. i believe my next move is to clean the radiator.
Old Jun 5, 2002 | 02:15 AM
Bob Mosaic's Avatar
Bob Mosaic
Default Re: I think it's radiator cleaning time (Rich_01659)
Cleaning the old one isn't worth the effort. It will most likely develope a leak shortly thereafter. I can get you a new one for 120 I believe. If interested shoot me a line at Zambezipt@aol.com. Gotta love my sales approach!
Cheers,
Robert
Old Jun 5, 2002 | 02:21 AM
GlockLT4's Avatar
GlockLT4
Default Re: I think it's radiator cleaning time (Bob Mosaic)
Cheers,
Robert
haha, as a college student with no $ left, i will use my stock for a little while. But I will get a new one from you if you can get them for $120.
Old Jun 5, 2002 | 02:22 AM
GlockLT4's Avatar
GlockLT4
Correct you are, which is why my next step is to clean the radiator.
Old Jun 5, 2002 | 10:23 AM
Denney's Avatar
Denney
Actually, any of the three can result in overheating. If the intake manifold gasket is leaking (and all of the C4's are prone to this) it will cause the engine to run lean (and thus hot) because the ECM is unaware of the added bypass air and is fooled into thinking it is running rich when examining the exhaust products. If the water pump is close to worn out, it will have much less effective flow characteristics and it too can result in running warm, this as a result of impeller wear. I can't say the GM stock pump was great, even new, but it works well enough. The radiator, well that of course is a no brainer. Since I had some minor issues with detonation prior to the intake manifold swap, I had to include it in the fix. As I said, this combo cured my problem, I can't say it will cure everyones.
Old Jun 5, 2002 | 10:36 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
When I pulled mine the area of the radiator in front of the fans was so full of debris that no air could get through. There was a clog area shaped just like the fans. So it made no difference when the a/c was on. I had no air movement in front of the fans at all. Of course cleaning made a world of difference.
Lone Ranger's Avatar
Lone Ranger
Hey, where is the most common point where the manifold gasket leaks? I'd like to make sure mine's not leaking false air.
Mine was just pulled and re-done when the dealership fixed the front main seal and the notorious intake manifold oil seepage leak.
To I think it's radiator cleaning time
Old Jun 5, 2002 | 12:29 PM
92corvette's Avatar
92corvette
Default Re: I think it's radiator cleaning time (Lone Ranger)
Curtis, I have the same symptoms this Dallas spring.
My fans already come on at 180 though. Temp will
stay about 185 till I turn on the AC, then it heads up
the scale quickly. It's gone up to about 227 till I turned
off the AC and the temp heads back down. I'm talking
about slow city traffic. On the highway, it doens't heat
up as much. I've got to clean my radiator out soon too.
I hope that takes care of it.
Old Jun 5, 2002 | 01:38 PM
GlockLT4's Avatar
GlockLT4
Ah, ok. That makes sense.
I might have a intake leak, but i doubt it (engine just redone). The water pump is less than a year old. The radiator has 138k miles on it and has never been cleaned :). I know which I'm going to do first, hehe.
Old Jun 5, 2002 | 01:42 PM
GlockLT4's Avatar
GlockLT4
The rear is the most common on ours. The front is no exception though.
