Fuel Line Question
Old Oct 13, 2012 | 05:02 PM
beerme's Avatar
beerme
Default Fuel Line Question
So had a bit of bad luck today, removing fuel filter I twisted my fuel line feed side and ultimately broke the end off.
Do I have any options for patching the connection or does the line have to be completely replaced?
The engine side of the filter connection is fine, I just lost the end of the feed side so roughly about 1 inch of tube plus the threaded bolt. I greatly appreciate suggestions on easy fixes....
Thanks in advance....
Phil
Old Oct 13, 2012 | 06:27 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
You can buy a used one from salvage yards such as www.vette2vette.com or you could go to a store such as NAPA where they could make you a new line. You would have to remove the broken line and bring it in so they could obtain the correct length. Then you could purchase a small tubing bender in order to make matching bends.
Good luck!
Old Oct 14, 2012 | 08:04 AM
joe paco's Avatar
joe paco
no reason not to replace with rubber fuel line and clamps, or a compression coupler. you probably have rubber on each ends of the fuel system, tank for sure.
if you have enough tubing at nut end, the compression coupler is available at hardware stores.
Old Oct 14, 2012 | 08:12 AM
ex-x-fire's Avatar
ex-x-fire
Most parts stores carry the Dorman brand, they have fuel line repair kits.
Old Oct 14, 2012 | 10:20 AM
leesvet's Avatar
leesvet
yep...either way you have to remove the damaged section to get it on the work table or get it matched up for replacement.
Its a simple matter to fix...but it will cost more than just replacing if you DIY...you have to get a tubing cutter, flaring tool, then the correct fittings. Just have the shop do it.
Joes right, rubber is an option but for that area...I dunno. steel is more durable and less likely to get punctured when hit by angry floor jacks or road debris.
Next time, USE a back-up wrench....short cuts usually lead to the long way around.
Old Oct 14, 2012 | 11:53 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Remember if yu use rubber for a temporary repair, it has to be high pressure fuel injection hose.
If you don't, the regular fuel line hose has a burst pressure of 25 PSI. you need a burst pressure of 75.
To Fuel Line Question
