Misfire Sensor
Old Jun 5, 2002 | 12:58 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default Misfire Sensor
Does a 96 LT4 have a misfire sensor or whatever to detect a misfire like a LS1/LS6???
Are LT4's 4 bolt mains?
Old Jun 5, 2002 | 06:18 AM
MJ's Avatar
MJ
Default Re: Misfire Sensor (Bluewasp)
All 96 LT-1/4s have a crankshaft position sensor and sender ring on the crank that is used to detect misfire. Corvette LT-1/4s have 4 bolt mains.
[Modified by MJ, 12:18 AM 6/5/2002]
Old Jun 5, 2002 | 09:58 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Default Re: Misfire Sensor (MJ)
Ok.. I wasn't sure but I thought since 96 was ODBII and ODBII came with the sensor for emissions reasons.
Lets say if there was a misfire. What would the dash say? Check engine? Or does it flash some other message?
robert
Old Jun 5, 2002 | 08:13 PM
MJ's Avatar
MJ
You get the "check engine" light. Then when you scan it (I use autotap) it will tell you what cyl and how many misfires the PCM is seeing. With aftermarket programming or LT1 edit for obd-II you can tell the PCM to ignore the misfires so that it won't turn on the light. I've seen even small cams trip the misfire light on the obd-II cars without programming.
Aloha,
Mike
To Misfire Sensor
