Idle problem is back, but this time with a code......
Old Jun 5, 2002 | 02:55 AM
OrangeC4's Avatar
OrangeC4
Default Idle problem is back, but this time with a code......
Looks like I spoke too soon with my idle problem being fixed. I was driving around all day yesterday with normal idle, and then today it came back. But, this time it threw a code 32 out. I don't have a vacuum pump to test the EGR solenoid, or a place to replace the EGR valve if need be. I replaced the brake booster check valve which was leaking, and can't locate any other vacuum leaks. I might just replace all the vacuum lines just in case. This will have to wait till I start school UTI, and have a huge workshop to work in.
Old Jun 5, 2002 | 10:23 AM
Lone Ranger's Avatar
Lone Ranger
Default Re: Idle problem is back, but this time with a code...... (OrangeC4)
Well, at least now you know where the culprit is.
Old Jun 5, 2002 | 08:37 PM
ittlfly's Avatar
ittlfly
The solenoid on my 92 was a snap to replace (1 bolt). The EGR required a bit more effort but it wasn't any big deal. Total was about $80.....cleared up my code 32 (knock on wood here) :lol:
To Idle problem is back, but this time with a code......
