For myself & my mechanic this has become a difficult trouble to track down.
'92 LT1 automatic 107k miles. Only mods, no mufflers & top off air breather. Replaced ECM 2 yrs. ago, plugs & wires 2 mo ago, tranny service 2+ yrs ago. Regular diet of 90 octane (no ethanol)
When driving on slight incline as tranny comes out of lock-up @ 40+/- mph seems to slip some, then engine runs very rough, bogs down, backfires slightly, & pinging. Moderate to strong acceleration & tranny downshifts & engine runs fine. Seems to be getting worse & more frequent.
No codes set. Mechanic thinks timing not advancing as it should.
not sure if this applies to your vette, i had a buick which had a vacuum controlled modulator valve for tranny. maybe start with that. vacuum loss = rough running. note; maybe move your post to tech for advice
Reason: note
Thanks for moving my thread over here.
Fuel filter has less than 10k miles on it.
As this condition occurs, the sputtering, missing, backfiring, pressing to WOT alleviates everything.
Don't think it'd be fuel related if that's the case???
Second mechanic (transmission specialist) looked at it Friday, & their consensus is now the distributor / opti-spark.
