Lt-4 hot cam install help..
do you have a specific question ? and yes, I dropped the pan and used a new gasket.
and there are two extra gaskets in the timing chain cover; one for the opti, which is pretty straight forward, and the second for the water pump drive. Lot of people have trouble with the water pump drive; not installing the seal itself, but installing the timing cover / seal over the water pump drive without damaging the seal lip. there are several low tech / low cost solutions to this issue; or the special gm tool.
This is my writeup on the HOT Cam and electric water pump install
You're barking up the wrong tree with this bs. If you want helpful information you need to characterize things correctly. The fuel cutoff is in the PCM code. Therefore either the engine had a tune to remove it and was highly modified to spin to 7500, or the dyno calibration was incorrect, or you're full of it. If it's modified, then you need to outline those mods and people can help accordingly. If it's modified and spun to 7500, then why are you de-tuning it with a HOT Cam install? What a waste.Go look at the cam specs on the stock cam or the HOT Cam...neither support 7500rpm. Put the crack pipe down and come back to reality. Think about it...a stock LT4 turning more rpm than a modified LT5?!?
Mad about mine not turning to 7000+?
My little 500+hp 383 peaked at 6300...oh snap...and if you know so much about these engines, why do you need help for a simple LT4 HOT Cam cam install?
Give me a frickin' break
