I've seen photos of two different Corvettes on Corvette Forum showing C4's with C6 (NOT Z06) wheels. I tried mounting the rear wheels of a spare set of C6 wheels I have, and found that the wheels hit a ton of stuff (inside forward wheel well, brake lines, sway bar, etc.). I couldn't even get a lug nut on. If I tried using spacers, my guess is I'd need 2.5"+. I've never seen spacers that big. Can anyone shed light on what those two people did to accomplish the mounting? Over two weeks ago, I sent messages to the two people who posted the photos, but have yet to hear from either. Thanks much, Jeff
If your talking about the wheels that are on my 89 in my avitar, they went on with no spacers, both on my 89 and I have now put them on my 94. Both with no spacers.
different wheel styles have different OFFSETS.
Yes, you may need 2" or more in spacers...OR the correct wheel for your yr. Plenty of aftermarket wheels made with C6 styles (clones) that fit C4s with the correct back-spacing.
C4s changed rear suspension geometry in 88. from 88 up it was slightly narrower. That caused the offset to change in the C4 wheels. Each generation has changed.
There are plenty of mfg to buy real billet spacer/adaptors for $80 a pair...sometimes less.
Actually, it wasn't your car, but yours looks great with the C6 wheels. The answer to my problem is in a response, below. Thanks for the response. Jeff
To you and Daffy2, I do have an 84. Have only had it a few months; bought it to autocross and only afterwards did I learn the nuances that separate the C4 generation years. I have decided to sell it and purchase an 89 and up car with a 6 speed. I suspect if I put the C6 wheels on the 84, they might stick out a little too much, but I'll keep that option open. Do you see any technical issues with using a very wide spacer? Thanks again, Jeff
I'm guessing you've got an early C4 (84-87) as opposed to a late C4 (88-96).
C5/C6 wheels can bolt onto a late C4 with little or no problems; putting them on early C4's cause issues because they have different suspensions.
-Tim
no, not a problem if its a quality chunk of aluminum. I've got 1.5" on the rear of my 87 to carry the 94 sawblade wheel correctly and bump it out a hair more.. No issues at all. The adaptors come with high strength bolts, recessed holes, so your wheel is being bolted to something just as strong as the hub. Avoid the plates and long bolts...thats where people get in trouble.
Thanks for the tip. I've seen several different sizes (up to 3") of the style you mentioned on E-Bay, so will definitely go that route. Thanks very much, Jeff
GM changed the suspension geometry in '88. The wheel offset changed (along with just about everything else). The later wheels won't fit correctly on the earlier cars without adapters.
This chart tells the whole story (note that the offsets are generally 56mm on the later wheels and less on the earlier wheels):
I get the drift now. No question, there are significant differences between my '84 and the '88 I just bought this weekend. I spent several hours comparing the two and there are many, many differences. The pre '88's are in a class of their own! Thanks very much for the hook to the chart. Jeff
