High Temp.
Old Oct 21, 2012 | 06:55 PM
Ho84Z51's Avatar
Ho84Z51
Default High Temp.
Hello Everyone:
My current condition may be normal but I wanted to check with the forum to see if I should be worried. When I start my 84 the temp climbs to 229 and then drops like a rock to 180 and stays there. My question and concern is if this is a normal condition? It seems pretty high to me before it stablizes. It runs perfect all the time but the high temp scares me. Any thoughts?
Old Oct 21, 2012 | 07:43 PM
chrldo's Avatar
chrldo
sounds like the thermostat is failing.
Old Oct 21, 2012 | 08:05 PM
gerardvg's Avatar
gerardvg
Originally Posted by Ho84Z51
Hello Everyone:
If your car is standard it should have a 190f thermo stat and the ecm will activate the cooling fan at around 230F.
You can fit aftermarket ecm chip and a colder t/stat.
If your water level is low or the t/stat bypass hole in block to bottom hole to water pump is blocked that can also explain your t/stat opening delay and or your thermostat is on the way out.
I have seen my vette do it once or twice in the past.
Old Oct 22, 2012 | 06:45 AM
Ho84Z51's Avatar
Ho84Z51
When it started doing this I replaced the thermostat and it made no difference so I assume that the hole must be blocked as you described.
Old Oct 24, 2012 | 02:19 AM
SouthCoaster's Avatar
SouthCoaster
That could be normal, assuming the warmup takes awhile passing 195F.
It should reach the thermostat setting, then actually drop a few degrees and hover there a minute or two before creeping up higher. Basically the thermostat is opening and the cold stuff in the radiator, and cooling of the radiator slows it down. Then at 228 the fan comes on, and brings it down to 218, then it repeats.
Old Oct 24, 2012 | 05:16 AM
gerardvg's Avatar
gerardvg
There is also a hose that goes to the heater that comes out at the front of the engine, try running the heater and see if this gets the thermostat to open as that will get water flowing past the base of the t/stat.
The temp sensor is in the head and will react more quickly than the thermostat, if there is no bypass flow past the thermostat the hot water will not reach it quickly having to rely on all the water heat conducting to the thermostat.
Also if your coolant (water) level is low it may not be touching the thermostat. Either way running the heater when you start the car till its warm will tell you, t/stats do have a slight weep hole to allow water to flow slightly you can drill a 1/8 hole to help get the water thru the thermostat.
Old Oct 24, 2012 | 07:04 AM
ex-x-fire's Avatar
ex-x-fire
I'd be concerned if its doing that while going down the road, sounds like there is air in the system.
Old Oct 24, 2012 | 09:05 AM
joe paco's Avatar
joe paco
Hello Everyone:
at startup, or after driving for some time? the temp can't drop as you describe unless t stat suddenly opens, and then it takes several minutes. sounds like a gage problem.
but 229 is not high. if fan is not on, it may not be an accurate gage.
Old Oct 24, 2012 | 11:41 AM
Ho84Z51's Avatar
Ho84Z51
The fan comes on at 205, the temp continues to climb for a couple of minutes to 229 and then drops like a rock to around 180 and stays there.
Old Oct 24, 2012 | 10:13 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
What brand thermostat and might it be the wrong one? I recently replaced the one for my 94 (LT1) twice as I found the ACDelco to be much better and react quicker than the Stant advanced model.
Given the traditional coolant flow direction of your year/engine (hot water exits thermostat), absent of a infrared heat-gun, you could use your hand to determine when the thermostat opens just by feeling for when the hose connected to the thermostat housing gets warm/hot and compare to the temperature gauge. If the hose doesn't gets hot until about 229, then that will confirm that the engine hot coolant is not reaching the thermostat to cause it to open.
This is likely occuring because air is underneath the thermostat. which could be caused by never having been properly bleed, or a leaking head gasket or a failing water pump or if there is a blockage in an air-bleed bypass hose or passageway.
To High Temp.
