Need help with antenna bypass
Old Jun 5, 2002 | 02:17 PM
Tim06's Avatar
Tim06
Default Need help with antenna bypass
Has anybody else done this? I'm looking for the rear body harness wire's white connector. It has 2 flat block connectors comming from the IP attached to it. I need to find Cavity C to clip the pink wire comming from it.
I can't find this harness. :confused: If anyone can tell me where it is I'd really appreciate it. I pulled back the carpet and found the wires but there is no connector and they are all taped up. Thanks!
Old Jun 5, 2002 | 03:53 PM
Tim06's Avatar
Tim06
Default Re: Need help with antenna bypass (Tim89)
I spliced it in the back instead just before the relay and ran it foward next to my seat. There were 2 pink wires back there. I just picked one, guessed, and spliced it into it. Seems to be working. My question is being that I went into only 1 pink wire is there any bad side effects of this. I'm not sure what the other wire is? If anyone can fill me in I'd appreciate it.
