Ooops!! Got paint on my paint.
Old Jun 5, 2002 | 02:32 PM
ZAD54's Avatar
ZAD54
Default Ooops!! Got paint on my paint.
I seemed to have driven through some gray paint without knowing it and it has dried on the lower half of the car. I have tried just about every cleaner with no results. The only think left to try is to wet sand the clear coat off and have it reshot. Anyone have any suggestions? :cheers:
Old Jun 5, 2002 | 02:44 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Ooops!! Got paint on my paint. (ZAD54)
You might want to consult with a reputable paint shop first.
Generally sanding is the last resort. If no cleaners work you might try a very fine rubbing compound.
Have you tryed kerosene or carb cleaner in some inconspicuous place?
Old Jun 5, 2002 | 02:48 PM
ZAD54's Avatar
ZAD54
Default Re: Ooops!! Got paint on my paint. (65Z01)
I tried the rubbing compound with no results. I took the side panel off and took it to a auto paint supply store and they used everything they had and it didn't even budge. :confused:
Old Jun 5, 2002 | 06:03 PM
TA's Avatar
TA
Try one of those clay bars. I've had success with this method in the past. :yesnod:
Old Jun 5, 2002 | 06:07 PM
ZAD54's Avatar
ZAD54
Default Re: Ooops!! Got paint on my paint. (TA)
I don't think a clay bar would touch it. I even tried to gently scrape it off with a razor blade and it didn't work very well. Thats some hard butt paint, battle ship grey and thick!!!! :mad
Old Jun 5, 2002 | 06:19 PM
TA's Avatar
TA
I'd give it a shot anyway........it may not work, but its cheaper than a repaint. You could also try laquer thinner depending on what type of paint it is. It shouldn't hurt you factory finish, but I'd still try it in an inconspicuous spot first to be on the safe side.
[Modified by TA, 5:21 PM 6/5/2002]
John Row's Avatar
John Row
Sounds like that epoxy paint I used to paint bilges. It that's the case, you may need help from your insurance company to get it off.
Old Jun 5, 2002 | 06:25 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Currently Corvette-less
Default Re: Ooops!! Got paint on my paint. (John Row)
Try "Goof-Off". I Guarantee it will work. I have used it for years, and yes, it will take off the epoxy paint that they use for line marking.
You can buy it at K-Mart, Home Depot, WalMart, etc ~ in the paint department.
It generally won't harm your original finish. Test to be sure though.
~ Purp
Old Jun 5, 2002 | 06:34 PM
guywade's Avatar
guywade
goof off comes water soluble as well, and might be a little easier on you r clear coat, good luck hope you get it off, , not sure also if a clear coat scrub from Mcguiars might work :D
Old Jun 5, 2002 | 06:57 PM
ZAD54's Avatar
ZAD54
Default Re: Ooops!! Got paint on my paint. (guywade)
Tried the McGuiars already, didn't do anything. I have no idea where it came from, I don't think it was there when I bought it but it looks like the paint the dealerships paint there service bays with. I can't remember the last time I had it serviced by someone with a painted bay. I guess I'll just get an estimate for a repaint if I can't get it off and eat my deductible. I hope my insurance agent doesn't put up too mush of a fight when he find out it will cost a few $GGGG to get it painted back right. MAybe I can meet him inthe middle and get a really good paint job worthy of a Corvette. I'll just keep my fingers crossed. :seeya
Old Jun 5, 2002 | 09:29 PM
nsimmons's Avatar
nsimmons
goof off is 90% xylene..you can get a big jug of xylene for the price of a little bottle of goof off.
Old Jun 7, 2002 | 10:11 AM
ZAD54's Avatar
ZAD54
Default Re: Ooops!! Got paint on my paint. (nsimmons)
Is xylene clear coat safe? If its strong enough to take off the enamel paint why wouldn't it take off the factory paint also?
Old Jun 7, 2002 | 04:18 PM
nsimmons's Avatar
nsimmons
i used it on my dads stang to take off a sticker..just wash it really good
xylene does eat everything
[Modified by nsimmons, 12:18 PM 6/7/2002]
Old Jun 7, 2002 | 04:59 PM
DaveD's Avatar
DaveD
You may have run thru some synthetic stucco mix/paint. I got that on the wife's car. Looks like thick paint. I have been told that you can buff it off if you are careful. I was also told to go to a detail place and have them look at it. Another detailer told me he could take it off with a 4000 PSI pressure washer. Haven't tried any of the suggestions yet myself. My plan is to find a detailer that thinks he can take it off without hurting the paint. What a mess.
Old Jun 7, 2002 | 05:40 PM
gbfan10's Avatar
gbfan10
I am fairly certain that you can buff it off. My dad owns a painting business and he oversprays my vehicles all the time. I use a Milwaukee Buffer and 3M Microimperial Heavy Duty buffing Compund. This has removed all sorts of overspray on my vehicles for me. For windows with paint on them, I have found Very Fine Steel wool works good as well.
I've repainted my 98 blazer about 3 months ago and was able to get overspray off with that method.
Hope it helps..
Old Jun 8, 2002 | 12:22 AM
Topload's Avatar
Topload
Bummer! The facilities idiots at my employer, spray painted the parking lot dividing lines with our cars parked on it! I now have tiny little yellow and white epoxy dots all over the hood and passenger side of the car. I've tried most of the methods posted here without any luck. Whatever that paint is made of it's a tough compound after it dries in the sun for awhile. In my case the dots are very fine and almost difficult to see - unless you're waxing the car or the car is under indirect lighting. I've resorted to machine buffing the hood with some 3M foam glaze but it isn't touching these d***ed dots. Guess its going to take sanding or some more aggressive rubbing compound. Hope you find an answer to getting the paint off your car without re-painting.
To Ooops!! Got paint on my paint.
