Just rehabbing my '84 that had been sitting a while and had the no start problem. I'd change the fuel pump & filter first (the pump is fairly easy to access once you remove the rubber shoe, and if the gas gauge isn't working you probably will need to change the sending unit too), syphon out the gas tank and fill with fresh regular gas, change the oil and filter, check the level and condition of the coolant (flush & replace as needed), and run it for 15-20 minutes checking the coolant temperature guage -make sure the ECM turns the radiator fan on at about 210 to 215 deg.F. Then drive it a while, do a tune-up (plugs & air filter at a minimum), and check the spray on the throttle body injectors -should be a nice even cone shaped spray). On a 28 year old car, brakes, tires, shocks, bushings, 4-wheel alignment, and troubleshooting (the almost inevitable) electrical problems would be next. Enjoy -it's a hobby right ?
Before changing the fuel pump, check the 10 amp fuse in the passenger side of the dash. You need to open the passenger side door to access the cover to the fuse block..
Always a good idea to check fuses first. You might want to check for voltage and proper grounding at the pump too, just incase there's a wiring issue.
The contacts on all my fuses had corroded/turned ugly. At first it caused no problems but then it caused one. I bought all new shiny fuses and cleaned the contacts wit DeOxit which is a great cleaner used by audio people. Available online, radio shack or cheapest at Sam Ash music stores in a big can.
PA, I ordered all through the web, some auto places tried to sell me the 8 injectors, others didn't have them so I made one order and it should all be here on Wednesday, same day as Sandy!
Were I you, I would try one thing at a time......in other words, don't pull the injectors just yet. Put the new fuel pump in place and see what you get. Also put a fuel pressure gauge in line while your hands are dirty and your tools are out.
So, New pump, with a FPG in line before the injector thingy......you may find that your injectors are working fine and you can return the two you bought.
I will do that, can you tell me if the pump was bad would I be getting good data from the sending unit? I do get good fuel level readings I believe, had a reading with the bad gas, emptied the tank and had a good reading and now I think a good reading with new gas added. The fuel filter looks like an easy replacement. 1985 model will be used.
The fuel level indication could be working without the pump working. When you first turn the key on you should hear the fuel pump run for about 2 seconds. IF you run a wire from a 12v source to pin G of the ALDL connector (under the dash by your right knee) your pump should run. If it doesn't run check for 12v to the pump at the filler..
Even if your old pump "Works"....does it reach the PSI needed for the injectors to fire??
I can't remember if it is 12psi or 15psi....but I don know that if your pump is only going up to 6psi, the injectors will not squirt.
That is why I suggested adding a fuel pressure gauge inline......just do it temporarily and lay the gauge somewhere where you can see it as you crank the motor. Later, when diagnosing a "cut-out" (if that happens) you'll need that same FPG taped to your Windshield so you can see if your pump is maintaining the minimum PSI and RPMS.....so you might as well dig into this now.....
oh, and just so you know ahead if time (since you are new to our forum) The '84 FP vs '85 FP is a huge debate........just be ready for it.....
I used to be a proponent of putting an '85 into an '84......but after hearing some good debate on the subject, I no longer feel that way.
I agree with the use of a pressure gauge, but I also think that you need to determine if you are getting power to the pump before you go to install a new pump. The normal pressure s/b 13psi..
I just bought an 84 in June. It runs pretty good for an old car. I hope you get yours running. I will be following your posts and learning as I go. My first vette and good luck with your new purchase.
