scanner needed for 93
Old Oct 25, 2012 | 10:11 AM
davewhtt's Avatar
davewhtt
Default scanner needed for 93
Any suggestions what to buy for my 1st scanner for my 93? Im not looking for anything to technical. Thanks Dave
Old Oct 25, 2012 | 03:25 PM
Bandit's C4's Avatar
Bandit's C4
Central PA Events Coordinator
St. Jude Donor '12-'13
Went with a Snap-on MT2500 scanner for a few reasons (known as the red brick).
a. Vintage OBD1 reader for that year (pre-OBDII).
b. Shows codes and live data... not just codes.
c. Was originally a $5,000 tool 20 years ago... now seen on ebay starting around $200 on up.
d. Various affordable plug-in modules available. The 2 modules specific to the 93 are:
  1. Primary cartridge for GM-Chrysler-Ford-Jeep (Domestic combination through 1996)
  2. Troubleshooter GM-Chrysler-Ford thru 1993
A few quick searches...
http://www.ebay.com/sch/i.html?_nkw=...=p5197.c0.m627
Good luck
Old Oct 25, 2012 | 06:23 PM
vetteoz's Avatar
vetteoz
What do you wish to use it for?
If all you want is to see the codes then you can display them on the dash by jumpering the ALDL connector terminals
See
http://www.corvette-guru.com/uploads...CMCodePull.pdf
Old Oct 26, 2012 | 12:59 AM
Cliff Harris's Avatar
Cliff Harris
...Or buy a relatively cheap cable (~$70) and get free scanner software for your laptop.
I have even heard of people taking their desktop computers into the garage to scan their cars. If you don't have to do it very often then that's a viable alternative.
Somewhere around your year GM started the "push a magical combination of buttons" to display the codes on the dash.
Old Oct 26, 2012 | 08:13 AM
davewhtt's Avatar
davewhtt
Ok guys thanks for your help
Old Oct 26, 2012 | 08:26 AM
davewhtt's Avatar
davewhtt
Ok is there a program called scanners for dummies? I have a lap top can you give me some direction where to get what else i need? Thanks Dave
Old Oct 26, 2012 | 10:27 AM
vetteoz's Avatar
vetteoz
You need this cable to connect the laptop to the ECM
http://www.aldlcable.com/
Download this program to datalog ( and adjust tune with other hardware)
http://www.tunerpro.net/downloadApp.htm
You need to download the files relevant to your car here to work with the program above
You need the two files in $DA2 row ( 92/93 Vette )
http://www.tunerpro.net/downloadBinDefs.htm
Then you will be back here asking questions on how to run it
Memorize this
http://ls1tech.com/forums/lt1-lt4-mo...-tutorial.html
Old Oct 29, 2012 | 08:10 AM
davewhtt's Avatar
davewhtt
Thanks your probably right.
Old Nov 10, 2012 | 04:46 PM
Pingman326's Avatar
Pingman326
Would there be any good reason to own MT2500 other than reading codes?
Old Nov 13, 2012 | 06:45 PM
Bandit's C4
It's not 'just' a code reader - it also shows live data from sensors, too.
To scanner needed for 93
