How many miles is too many
I have seen many cars with 1/4 mil miles that were running just fine, reliable and dependable. As matter of fact, my engine is pushing 200K, chassis is 300k and Its a DD. BUT ! I DO the maint and I fix things. I use quality lubes, change them often and stay on top of any leaks, noises or other warning signs. Everything wears...things break when they are ignored too long.
When to walk?
When someone has no documentation on the maint. When they are showing you a car t hey put 100,000 miles on and cannot produce and records. Sticks are scarey, and cars that have aftermarket junk glued and bolted on everywhere. Aftermarket alarms, stereos, and other electrical trash are warning signs of amature engineering.
Go by the simple rule of thumb...
about 100,000 miles for about $10,000 for 20 yrs or less. With maint records...that should not be a problem.
I see '86s that will sell for $12,000 but its got less than 30K miles and its showroom fresh. I also see 2005's that sell for the same price that have had the dog $hit run out of them and show obvious signs of abuse.
I once walked by a Corvette and looked inside to see the ashtray STUFFED full of butts and ashes all over the console. I was tempted to wait to see what kind of animal would do that to a world class car...Even cleaned up with low miles, that car would not bring more than $3000 because of the neglect. Its shocking at how some low class people abuse their cars by not changing oil but every 25,000 miles or ever changing the coolant...
When shopping, look the SELLER as well as the car but decide based on the maint records, or lack there of. I've walked away several times when the seller was some wanna be hot-rodder that talked like he was Knight-Rider and his street stories were too "fast and frivolous" for my liking...
If you can do the work yourself then the cost is not bad. If you have to take it to someone to do the work then it can get expensive. Parts for above were about $375 total. The labor charge for a shop to do the work would be more than that.
It also means a few things will need to be serviced or replaced. That can be expensive.
If the price is right <10K and the interior is in good condition. This is good.
Here are some numbers to consider when negotiating a price;
Seats and carpet = 1000 - 1500
Tires = 1000
Shocks = 400
Brakes = 200-400
Paint = 5000
Remote key entry = 300-500
Trans = 2000
These numbers are rough but can give you an idea what $$ your looking at should these items need replacing.
Good Luck
& everyone facing seats...
I found a decent alternative thats not too bubba and maintains the style of the Vette...
I was sick to death of my sport leather that did little more than burn my hide off living in Phx...and it dried and dry rotted,. leather kits were $1100..per seat. Ain;t happenin.
Sooo
I got a auto interior seamster (?) a guy that sews seats... and we found some marine grade HD vinyl and used that instead. Just as suple,looks like faux leather and has a very high UV rating good for years since it was designed for boat seats in the salt water !
Got the 2 seats recovered for a total of $400 labor and materials. And as a nice surprise...they just happen to be the same color combo of the 2012 ZR1...grey on drk grey, looks good!
Just remember...,Marine Grade Vinyl...its a whole other class of vinyl and offers much higher quality and colors than the standard automotive vinyls that are usually what you have to choose from.
When to walk?
Sold my S10 and BMW because I didn't drive them any more after I got the Vette.
My 93 had 59,000 when bought last Spring. Still had 20 year old parts and growing lazy.
Had to play catch-up with the lack of prior maintenance just to get it back to shape.
Since then: fuel sending unit, fuel pump/sock, fuel filter, fuel pressure regulator, injectors, tires, shocks, bushings, throttle position sensor, map sensor, plugs and wires, idle air control, coil, and ignition control module.
The only visible changes (from the previous owner) were the slotted discs and pads in the front.
The Corvette is now refreshed, renewed, and responsive.
{Am a big proponent on preventive maintenance.}
However @ 140K - need a indepth inspection, first at a reliable shop.
If I was looking for a vette I'd look for who passed the under hood tests with decent interior AND weatherstrip.
If you don't intend working on it yourself pass it up and look for a C5 or C6. Like everyone said something almost 20 years old will have some issues. Labor is what will eat you up.
My 87 with 240k miles has never spent the night inside in 20 years. I think the body will rot off before the drivetrain wears out.
JS
I'm giving you 'garage' prices, sometimes I did it myself, sometimes not.
FSM - full shop manual, do not even think about buying a C4 without it!
Optispark - read all you want here, bad design, $800 or so at a garage
Heater core - also about $800 at a garage
Wheel bearings - only 1 failed so far but then I replaced all, maybe $6-800
Car stereo - mines been rebuilt twice, $200-500 depending on extent
Interior - I got iggoo (sp) seat covers, they certainly look better than tattered leather, about $250?
Plugs and wire set - $300 because of garage labor, parts not bad but this is the one thing I did that most improved my cars performance/idle
Headlight motors - I'm on my 2nd/3rd set, easy to do, $200 each
Various little interior switches, door closed, power locks, etc, cheap parts really and easy to install
Weatherstripping - ugh, mine is shot, needs $500 worth in parts
Injectors - I probably needed new ones awhile ago, $200 or so, easy to install
02 sensors - $40 each, I keep thinking I should replace mine just cause they're so inexpensive but, I haven't
Shocks - you can go cheap with Monroe for $100 or better for more
Some of these items you KNOW when you need, others, not so much. Thats the fun of it. Right??
