Harmonic Balancer Wobble ?
both times the harmonic balancer outer ring had moved from the hub, they always move toward the timing cover when you hear a scraping noise it is already too late.The race type will not explode or allow the outer ring to move backwards
(man was a lot cheaper when i got mine).My race balancer has nice timing marks all around it very clear to see when adjusting timing, i know it is over kill for a TPI but worth it in the long run as it will outlast many std harmonic balancers.
Needless to say i have not had a problem since, I will never go back to a standard balancer again. It is a real pain to have to replace the timing cover (unless you want to upgrade to a double row timing chain at the time)
http://www.ebay.com./itm/Pro-Race-St...item4abd89d8db
I've heard updating to the 85 fuel pump is best, BUT it must be regulated down to 15 or 14 then the stock regulators can bring it down to 13 or 13.5 as needed,
While others suggest that the stock replacement pump is just fine.
Once i work out all the bugs i'll start testing fuel pressure and see what works before i spend more on fuel system upgrades beyond stock.
I did install a new knock sensor recently and new ESC module, however the original wire to it was not connected.
I soldered on a new wire to the blue module wire and it ran ok, BUT when started cold bluish smoke blew out the exhaust, then it felt like it wasn't running on all cylinders weird miss, then finally it would not start.
Disconnected the knock sensor, checked base timing with est wire disconnected, reset the ecm by disconnecting the battery now starts and runs as good as before.
So further testing is needed but until then knock sensor is not hooked up.
The outer ring on both the '78 and the '86 came loose from the hub. I found the problem on the '78 when I tried to set the timing and the engine wouldn't even run when I lined up the mark. The '86 balancer ring moved inward until it hit the timing chain cover and ground a hole in it. I found that when oil started pouring out. I filled the hole with J.B. Weld about 10 years ago because I didn't want to go through the hassle of replacing the timing chain cover. Still holding so far...
Although you are correct sometime in the early life of the SBC the damper was not retained by a bolt.
Mike
MIke
Eroded plugs can cause rough running do those first. If it still pops under WOT Id be looking at your valvetrain (cam lobes)
