No start
Old Oct 27, 2012 | 01:57 PM
hobbs vette's Avatar
hobbs vette
Default No start
At first turn of the key the motor almost catches then it just keeps turning over. I can hear the fuel pump prime, put in a new fuel filter, still no start. Any thoughts? By the way, what is the filter just above the fuel filter? It's a canister type.
Old Oct 27, 2012 | 04:56 PM
hitmanpty's Avatar
hitmanpty
you have to check the basic first.
spark
fuel
timing
fuel preasure will be a good idea too
Old Oct 28, 2012 | 05:15 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
That second filter is the return filter to keep the fuel return ines from banging against the frame when the engine is cold.
It is an old service bulletin.
um..............are you thinking what I'm thinking? change that thing and see if things get better.
In all reality, I think you have a distributor module problem.
Old Oct 28, 2012 | 08:07 PM
hobbs vette
Yes I guess i'd better change it, it,s 25 years old. Is there an easy way to check the distributor module that you know. Thanks for the info.
Old Oct 28, 2012 | 08:43 PM
vetteoz's Avatar
vetteoz
Originally Posted by hobbs vette
Is there an easy way to check the distributor module.
http://easyautodiagnostics.com/gm_ic...n_module_1.php
http://forums.carcraft.com/70/661769...odule-testing/
To No start
