Lowered Vettes...what are the drawbacks?
Old Jun 5, 2002 | 10:21 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Default Lowered Vettes...what are the drawbacks?
I'm seriously thinking of lowering my Vette approximately 1" with the VB lowering kit or something similar. Are there any drawbacks involved as far as drivability?(i.e.speed bumps,potholes,etc.) With the condition of the roads around here (Horse & Buggy country :D) I'm having some concerns. :yesnod: :cheers:
Old Jun 5, 2002 | 10:29 PM
vettewrench's Avatar
vettewrench
Default Re: Lowered Vettes...what are the drawbacks? (Hardcorvette)
I had my last vert slammed with the X brace i scraped everything.
Just lowered my partners coupe and you just have to be aware that it is lower.
not to bad at all :cheers:
Old Jun 5, 2002 | 10:32 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
My car is down about 2 inches and I don't have much of a problem... I do tick people off when i'm pulling into a driveway or going over speed bumps thou... I take my sweet time. On the road it's not bad at all... course the roads in FL are nearly perfect. If I was in a northern state.. I prolly wouldn't of gone down two inches... but 1 and you should be safe.
My ride actually improved after lowering the car... enough so that even my girlfriend noticed it 1st time out.
Old Jun 5, 2002 | 10:49 PM
MinnesotaRagtop's Avatar
MinnesotaRagtop
Default Re: Lowered Vettes...what are the drawbacks? (vettewrench)
89 C4, any major complications to lowering those models that are aware of, or pitfalls to watch out for when doing the job?
it just seems that this car should be lower than it is...
Old Jun 5, 2002 | 11:11 PM
Jasin9687's Avatar
Jasin9687
Default Re: Lowered Vettes...what are the drawbacks? (MinnesotaRagtop)
Its not to bad, the only prob I have is the front plastic peice scrapes Alot going into parking lots and stuff, but Its not hurting anything
Old Jun 5, 2002 | 11:47 PM
GS 163's Avatar
GS 163
Default Re: Lowered Vettes...what are the drawbacks? (Springer's 95)
What Springer said.:)
Old Jun 6, 2002 | 08:41 AM
LD85's Avatar
LD85
Default Re: Lowered Vettes...what are the drawbacks? (JPLT1)
My suggestions is to try just the rear first then consider the front. The rear is a 30 minute job, the front a 5 hour job. I did mine on jacks in my garage and then you must have it re-aligned afetr becasue most of your settings are wacked out after the procedure. In retrospect, I would have only done the rear. The front rides really stiff and is non reversible unless you want to put the rubber back in after cutting it off of the spring. In the front you put in apiece of hard plastic and like a I said when you hit a bump hard enough you feel it. The rear you can adjust back to stock if you like.
The up side is it looks really great IMHO and you really dont hurt anythnig. I have 315's in teh rear and there are no problems althoug I did adjust my raer a littlle too low and would rub the inner wheell well when I hit a dip in the road. :cool:
Old Jun 6, 2002 | 10:06 AM
rodj's Avatar
rodj
Say goodbye to the rubber spoiler.
Old Jun 6, 2002 | 10:31 AM
Psychotron's Avatar
Psychotron
Default Re: Lowered Vettes...what are the drawbacks? (rodj)
If you decide to do it, take a before and after shot so we can see the difference it makes! :)
Old Jun 6, 2002 | 11:03 AM
LD85's Avatar
LD85
Default Re: Lowered Vettes...what are the drawbacks? (OTCgrad)
On my web site there is a before and after and yes the rubber spoiler takes a beating!
Old Jun 6, 2002 | 11:09 AM
Springer's LT4
Default Re: Lowered Vettes...what are the drawbacks? (ld85)
I can't remember the last time I scraped my spoiler.... I'm just careful pulling into places.
Old Jun 6, 2002 | 11:33 AM
LD85's Avatar
LD85
Isnt everything is St Pete below sea level or going down hill to sea level? :lol:
I lived in Clearwater for 15 years, say hi to the hot dog vendors if they still allow that down there :yesnod:
Old Jun 6, 2002 | 01:14 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The rear sat about 1 1/4" higher than the front so I dropped it that amount and the results are great.
The car looks and drives much better than before; since I don't ofter cruise above 150mph I'm not worried about front end lift due to lack of rake.
Since I only lowered the rear the air dam is actually slightly higher than before.
To Lowered Vettes...what are the drawbacks?
