Front spindles
Old Oct 28, 2012 | 09:51 AM
87vettevert's Avatar
87vettevert
Default Front spindles
Are 88- 96 front spindles (steering knuckles) a direct bolt on for a 1987 Corvette, I am already upgrading the brakes to j55. Just curious.
And will the wheel offset change?
Old Oct 28, 2012 | 10:09 AM
leesvet's Avatar
leesvet
Nope !
spindles are different. Steering geoometry changed 88 up. thats why the wheel offset changed...to compensate for the different spindle location.
Wheel offset is 18mm different. You need a 3/4" spacer/adaptor to make the difference up. Most just go to 1" to fill the wheel well. 3/4 front, 1" rears. Adaptors are not bad...$60 a pair for good billet alum.
Thats IF you are going to 17 or 18" stock Corvette wheels...there are plenty of aftermarket wheels cast with the 84-87 offset of 32 or 38mm offset.
Stock Corvette 17" went to 56mm.
You don't have to trade spindles to add big brakes...there are adaptor brackets that fit the j55 or zo6 caliper to the 87 spindle...then all you have to be concerned with is the fitment of the caliper inside the wheel....sawblades are F'n close! I mean paper thin clearence between wheel and caliper. Your adaptor/spacers help push the wheel off the spindle a bit more so that helps since the inside of the wheel is a semi taper.
Old Oct 28, 2012 | 11:17 AM
87vettevert
Originally Posted by leesvet
Nope !
Thanks leesvet,
I have the 17" ZR1 replica A-molds on it now, I may just break down and buy the adaptors
Old Oct 28, 2012 | 01:04 PM
leesvet's Avatar
leesvet
Originally Posted by 87vettevert
Thanks leesvet,
if these reps were made with the early c4 offeset, as many are, you might be ok. 18mm does not seem like much but it matters when the clearences get to within a couple mm between caliper & wheel.
When I was building my last upgrade I laid the rotors with caliper inside a wheel on the floor and was shocked at how tight it was...not much wiggle room. Wheel has to go straight in onto the studs. No room to wiggle it to fit or find the studs..
Search EZaccessory for the spacer/adaptors. They sell on fleabay and have a website. Get the "concentric" style also...they are easier to fit on the hub and stay centered.
Old Oct 28, 2012 | 01:55 PM
DanZ51's Avatar
DanZ51
Nope !
Youu don't have to trade spindles to add big brakes...there are adaptor brackets that fit the j55 or zo6 caliper to the 87 spindle...then all you have to be concerned with is the fitment of the caliper inside the wheel....sawblades are F'n close! I mean paper thin clearence between wheel and caliper. Your wheel spacers help push the wheel off the spindle a bit more so that helps since the inside of the wheel is a semi taper.
I'm running replica A-molds with C5 brakes up front. No fitment problems at all. wdo-mkr made my C5 brake adapters quite a while back. I had some J55 brakes on my shelf and was looking for adapters when the C5 style became available. I dumped the J55 and went with C5, and glad I did.
To Front spindles
