stupid radiator
Old Oct 29, 2012 | 12:47 AM
84VetteMan205hp's Avatar
84VetteMan205hp
Default stupid radiator
i started up the car to move it to the other side of the drive way, (had to be on for less than 30 secs) i popped the hood and open the radiator cap because its saying LO and there was this thick foam sitting on top i thought since the car has been sitting for a while its time for a flush i pulled the plug let it drain out water hose let it run threw plugged it back up and went to put some coolant in it when it started pouring from the bottom right hand corner like there is a crack. but what i don't get how could it crack when the motor was not running, the motor was room temp has this ever happened to anyone else. is there like another plug that came loose and i didn't notice or something? o yeah its an 84 its been sitting since July and for six years before that. i just shipped it to AZ from CA yesterday.
Old Oct 29, 2012 | 01:30 AM
84VetteMan205hp
could it be a lower sensor
84wannabezo6's Avatar
84wannabezo6
I just changed mine for an all aluminum dual core so I have a spare that is perfectly good. search the forum they are using an inexpensive two row that everyone seems to like.
Old Oct 29, 2012 | 10:37 AM
383vett's Avatar
383vett
Definitely a stupid radiator.
Old Oct 29, 2012 | 10:55 AM
lt4obsesses's Avatar
lt4obsesses
From your pics, it looks more like a '94?
Are you sure the drain plug was secure?
Also if you had foam in the system after running, I would think that air is getting in somewhere.
Check hoses, connections, including heater hoses etc.
If it's a '94, the right side of the radiator is plastic, and can be prone to cracking. Check for cracks along this part, especially at the connections.
Old Oct 29, 2012 | 12:32 PM
Deepa's Avatar
Deepa
Good thing you ended up shipping it rather than drive it...
Old Oct 29, 2012 | 12:47 PM
leesvet's Avatar
leesvet
Cracks are not that unusual...the tanks are not even secured by anything other than the tiny clamps along the edge of the metal core. These lite-weight radiators are cheap and not worth repairing IMO...they're throw-aways. You can buy a stock rad for $85 or something thats all aluminum and extra capacity for $200. All the coolant and a couple new hoses cost more than the radiator these days...
Old Oct 29, 2012 | 04:01 PM
jhammons01's Avatar
jhammons01
The only thing I'll add is, on the '84 we didn't have a low coolant gauge like the later years, if you buy a new radiator, you'll have to buy that sensor to fill the hole in the radiator......just stick it in there as you won't have a wire to hook onto it.
Old Oct 29, 2012 | 06:46 PM
84VetteMan205hp
man this really sucks the guy messed up my tire fo i have to replace that buy a new radiator and get a tune up wow this is going to cost alot
To stupid radiator
