84 hesitating bad under throttle. Please Help!
Old Nov 2, 2012 | 09:58 PM
floridafisher's Avatar
floridafisher
Default 84 hesitating bad under throttle. Please Help!
84 vette that has been maintained. I got a check engine light a few times last week. I read the code and it was 13-oxygen sensor. The car ran good, but I replaced it since the CEL came on more than once. So, I replaced the 02 sensor with an oem sensor and the car started running terrible.
It idles fine, but under throttle it's hesitating bad. I changed the o2 sensor again, thinking I may have gotten a bad one from the dealer. It's still running rough. It hesitates after you are going about 15 mph. I've tried mashing throttle, medium throttle, and light throttle. It does it under any circumstance. There are no codes present. It had new fuel filter, fuel pump, plugs, wires, cap etc only a year ago. I'm confused because it ran fine before replacing the sensor. Is it possible the cat converter is clogged and it showed up in the system as oxygen sensor? - but why would new 02 sensor make it worse?
It feels like it's running on 4 cylinders and I swear the car is much quieter now- and not it a good way. Motor was completely rebuilt less than three years ago, so I'm thinking it is something simple. Also, put some injection cleaner and iso heet thinking I may have picked up bad gas...didn't help. Thank you for any suggestions.
Old Nov 3, 2012 | 04:09 PM
floridafisher
Anybody? What are symptoms of a clogged cat converter? I swear the car is quieter now.
Old Nov 3, 2012 | 05:36 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Step 1 on this car: Check the Fuel pressure.
I know you changed the pump etc a year ago. Doesn't matter (especially if you used an '84 replacement pump).
If you REALLY think it's the cat, install a vacuum gauge. Should read somewhere around 18" at idle. Crack the throttle and hold steady at say, 2500 RPM. What SHOULD happen is the vacuum gauge should drop sharply as you crack the throttle, then rebound quickly as RPM stabilize at your target (~2500) and end up at about 21" or so.
IF your cat (or muffs) is clogged, then what will happen is you'll see the gauge drop, rebound (as would be normal) then start dropping away again. That is as pressure builds in the exhaust, it also builds in the intake too...giving you a lower vacuum reading. That is a dead give-away. Falling off vacuum at high RPM/low load is a sure sign of a backed up exhaust.
Old Nov 3, 2012 | 05:53 PM
1984crossfirefuelie's Avatar
1984crossfirefuelie
Probably is your cat my dodge pickup did that to. Unbolt the cat and rev it up. You can buy a straight pipe off of eBay for $50 bolts right up. Boost in performance and never worry about a plugged cat again.
Old Nov 3, 2012 | 11:52 PM
floridafisher
How do you check fuel pressure? Would it be easier to just replace the fuel pump? I read somewhere that it's a pretty easy job. As far as the straight pipe on ebay, consider it done. I'm sure it's a noticeable difference and I'll never have to worry about it again. I appreciate the recommendations guys.
Old Nov 4, 2012 | 12:01 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If you have a gauge, it's easy. Just "T" into the fuel line by the filter using some fuel hose, hose clamps and a "T".
Spec is 9-13, but you're looking for 12-14 PSI.
Replacing the pump is pretty easy. Not as easy as checking pressure, but close. Why waste money though? Diagnose the problem.
Same goes for you "clogged cat". Diagnose first, then replace.
Old Nov 4, 2012 | 03:17 PM
floridafisher
I don't have a gauge to check fuel pressure. I'm going to take it to an exhaust shop tomorrow. They said they would test it for free. Already bought new plugs, so I plan to do those after work tonight. May pick up a fuel filter as well. It looks easy to change since the location is easily accessible. Maybe that will take care, but I suspect the cat is the issue. I'll keep you posted and thanks for the replies Tom!
Old Nov 4, 2012 | 09:32 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Looking forward to hearing what you find.
Old Nov 7, 2012 | 03:11 PM
floridafisher
I have good news, and some not so good news. I deleted the cat and ran a straight pipe as someone suggested. It didn't change anything as far as the hestitation goes. I finally got to the plugs this morning and...WOW what a difference. The vette runs better than it ever has! One of the plugs was awful. It had grease and oil all over the end of it. The rest looked pretty good, but that one plug definitely was the problem.
Now my concern is what caused that. Could the 02 sensor being bad cause any of it, or is it something worse? Thankfully it's the easiest plug to fix, so I may just replace that one every 6 months or so. Any input on the dirty plug? Thanks again for everyone's input!
Old Nov 7, 2012 | 03:44 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Ah HAH...so it WASN'T the cat! See why it pays to DIAGNOSE, rather than guess (ahem! 1984crossfirefuelie)
Now my concern is what caused that. Any input on the dirty plug? Thanks again for everyone's input!
An improper A/F ratio (cause by a Faulty O2) coudl blacken a plug. The soot could build to the point where it was literally "chunks" on the end of the plug, but it would be a dull/flat black...not "oily/greasy". Oil/Grease looking is probably caused by...oil. Run it for a bit, and pull that plug again for inspection. If it's oily looking again, time for a compression test, or a leak-down test. Are you consuming (losing) oil?
Old Nov 7, 2012 | 03:51 PM
floridafisher
That is what I wanted to hear. It isn't oily, its chunky grease like you just described. The straight pipe was only $40 installed and I never have to worry about the cat. When I get home tonight I will upload a pic of the plug, but yes it was def chunky grease. It doesn't use or burn oil, so I'm guessing it was that crappy o2 sensor. Guys, change em out before they give you issues. Best $20 buy imo. Thanks for the reply.
An improper A/F ratio (cause by a Faulty O2) coudl blacken a plug. The soot could build to the point where it was literally "chunks" on the end of the plug, but it would be a dull/flat black...not "oily/greasy". Oil/Grease looking is probably caused by...oil. Run it for a bit, and pull that plug again for inspection. If it's oily looking again, time for a compression test, or a leak-down test. Are you consuming (losing) oil?[/QUOTE]
Old Nov 8, 2012 | 08:41 PM
floridafisher
Here is a pic of the plug. What do you think Tom? Definitely greasy!
http://i113.photobucket.com/albums/n...2/IMAG0520.jpg\
Old Nov 8, 2012 | 09:45 PM
1984crossfirefuelie
With the cat gone and new plugs I bet you gained 10 hp with the cat gone.
Old Nov 8, 2012 | 09:52 PM
floridafisher
It runs so much better! Now, if I can figure out why it is running a little hot I will be a happy camper.
Old Nov 9, 2012 | 10:04 AM
1984crossfirefuelie
You could put a manual fan switch in it to control the temp yourself. You could put a 160 degree thermostat in it.
Old Nov 9, 2012 | 10:46 AM
mtnmanut's Avatar
mtnmanut
Old Nov 9, 2012 | 12:03 PM
glava2876's Avatar
glava2876
It feels like it's running on 4 cylinders and I swear the car is much quieter now- and not it a good way. .
I had muffler eliminators on my 84 with the stock cat and it was pretty loud and then at about 87,000 miles it felt like it was on 4 cyl also, would just not get above like 3k rpm and sounded like I had put mufflers on it!
I installed a magnaflow high flow cat and what a difference -seemed better than ever.
To 84 hesitating bad under throttle. Please Help!
Old Nov 11, 2012 | 02:03 AM
jhammons01's Avatar
jhammons01
Dude, don't give out bad info......if he has a 4x3 (which you haven't determined in this thread) and you put a 160° thermo in there, while he is going down the highway on cool days, and once his temps drop below 159°, his overdrive will kick out unexpectedly.....
Plus there is no sense in having a cooler thermostat despite what you "think"....
And Engineers designed this really cool switch (pun intended) that controls the fan Automatically! The Driver merely need to control the direction and the speed of the car whilst this "cool" automated system handles the temps devoid of driver input......imagine.....
Old Nov 11, 2012 | 11:52 AM
1984crossfirefuelie
Plus there is no since in having a cooler thermostat despite what you "think"....
If the automated system is not working properly its a cheap option. I said he could do this not that he should. You could tell him how to fix the problem instead of trolling on me.
Old Nov 11, 2012 | 12:00 PM
jhammons01's Avatar
jhammons01
Adding a switch in the cockpit is addressing 'anything'?? Tell me how, be specific
putting a lower temp thermostat is addressing 'anything'? Tell me how, be specific.
