Clutch Problem
Old Jun 6, 2002 | 02:26 PM
dans86's Avatar
dans86
Default Clutch Problem
I had my car jacked up today tracing a fuse link and when I put it on the ground and was putting it away I couldn't put in any gears, I thought the cable had come off the pedal (happened before) that was ok. I checked the fluid and that was about 3/16" below the add line so I'm thinking I got air in the line and now I need to bleed this thing. Anything else I need to look at.
Old Jun 7, 2002 | 12:17 AM
GRX's Avatar
GRX
Default Re: Clutch Problem (dans86)
:confused: ...the clutch is hydraulic; not actuated with a cable.... start with the cheapest/easiest solution - bleed. It's a long shot. Remeber to bleed with the slave cylinder OFF the bellhousing...with the bleed nipple upwards of the entire slave cylinder. Good luck.
Old Jun 7, 2002 | 04:42 AM
tarheelracer's Avatar
tarheelracer
Default Re: Clutch Problem (GRX)
If bleeding doesn't work you'll probably have to go for a new slave or master cylinder.
To Clutch Problem
