quick! Help removing my 91 door panel
Old Jun 6, 2002 | 04:26 PM
soundkillr's Avatar
soundkillr
Default quick! Help removing my 91 door panel
I am removing the passenger door panel on my 91, I have all screws out except the screw behind the lock rod, to the door handle face. How in the world do I remove that screw?
Old Jun 6, 2002 | 06:11 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default Re: quick! Help removing my 91 door panel (soundkillr)
I just emailed you this response....The black plastic lock lever pops off quite easily from the lock rod. Then you can access the screw behind it. Hope that helps! ;)
Old Jun 6, 2002 | 07:35 PM
BiZ's Avatar
BiZ
Default Re: quick! Help removing my 91 door panel (brdd)
Don't forget the screw behind the power window switch either.
To quick! Help removing my 91 door panel
