odometer swap
Old Nov 6, 2012 | 12:50 PM
locknessmonster's Avatar
locknessmonster
Default odometer swap
Hey guys, since you guys have had the answer for everything so far, I have another question... can anyone tell me how to remove/swap out the odometer on my 84 corvette? I have a new digital cluster I have to put in, but I want to keep my old odometer. I pretty much have the cluster out...just have to figure out how to unplug the wires(I read a thread on here how I have to pull up the dash a little and pull out) but my main concern is the odometer change. Thanks
Old Nov 6, 2012 | 12:58 PM
THE 383 admiral's Avatar
THE 383 admiral
You would like to retain your mileage correct? The BCM module.. contains this information.
Old Nov 6, 2012 | 01:02 PM
locknessmonster
Yes, that's exactly what I am trying to do. So I am confused... I do not need to take the odom. out? it will recognize the mileage? (sorry, i am not too good in the old mechanical knowledge category)
Old Nov 6, 2012 | 01:55 PM
THE 383 admiral
I know in most GM cars the BCM is a eprom. I'm not sure if its soldered in
Old Nov 6, 2012 | 02:04 PM
locknessmonster
Ok.. I have no idea what your speaking of. Are you saying the odometer might be soldered into the cluster? Can anyone who has done this before tell me how to take it out? Can i just pry the two "screws" holding it in off?
Old Nov 6, 2012 | 02:06 PM
Chuck Tribolet's Avatar
Chuck Tribolet
My '87 has an old-style mechanical odometer. I strongly suspect the '84
does too. I don't see how the BCM would be involved.
Chuck
Old Nov 6, 2012 | 02:11 PM
locknessmonster
Chuck
yup, that is spot on. Same thing here. I'm pretty sure this thing just comes right out and I can swap em out. I just cant figure out how to remove it. Theres two screws/bolts on the front of it, but not sure how to get them out.
Old Nov 6, 2012 | 02:50 PM
WVZR-1's Avatar
WVZR-1
Try this:
Odometer Motor Removal Procedure
After removing cluster from dash:
1.Place the cluster face down on a soft towel on a smooth surface
metal rear cover on top).
2. Remove the 7/32 inch headed screws holding the cover to the cluster and lay the cover to the side.
3. Locate the wires coming from the odometer motor to the PC board and unplug the connector.
4. Remove the three 7/32 inch headed screws holding the odometer to the cluster.
5. To reinstall the motor assembly, reverse the above procedure.
Old Nov 6, 2012 | 02:51 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
My 84 is mechanical.. IIRC early C4's didn't have a BCM, started about 1990?
Old Nov 6, 2012 | 02:53 PM
locknessmonster
Originally Posted by WVZR-1
Try this:
THANK YOU! this is EXACTLY what I was hoping for.
Old Nov 7, 2012 | 07:43 AM
locknessmonster
Thanks for the help guys, swapped the cluster and odometer last night, no problem. A little tight trying to get the new cluster in it's spot, but with a little gentle force I did it. WVZR...that helped alot thanks!
Old Nov 7, 2012 | 02:05 PM
WVZR-1's Avatar
WVZR-1
Good to see someone come back and mention "success"!
To odometer swap
